Firmware for network adapters
I don’t seem to have a wireless device in Network Manager even after attaching the internal wireless device in my computer to sys-net. Do I need to install firmware? I haven’t tested my USB network adapters but maybe I need firmware for those too.
Have you checked with lspci/lsusb if the controller is recognized in dom0 / the VM?
It’s unlikely that you need to install drivers if you don’t use a minimal VM .
Should I attach the wifi device to sys-net and then check lspci/lsusb in dom0 and in my app qube? I tried that and there is nothing in lspci or lsusb but I’m guessing that’s not the right way to do it.
Any tips? If I attach the internal wifi device to sys-net, should something appear in lspci or lsusb in dom0 or in the app qube?
are you using a minimal template for sys-net?
I’m not using a minimal template anywhere according to Qubes Manager.
