Hello,
I would like to know two things.
First, is it possible to use Qubes OS configuration to block certain website when you are using a Wireguard or other VPN setup like this one : Wireguard VPN setup ?
For example, block all incoming traffic from Wikipedia that pass through the VPN ?
Second, is it possible to just block / drop all incoming traffic from a particular website by blocking it’s IP address but allowing all other website ? So basically something different from the “Allow all outgoing connections” / “Limit outgoing connections to …” ?
Thank you for your time ![]()
