Firewall rules ignored
hi,
i have a sys-vpn qube set up to which sys-whonix provides networking
in sys-vpn i have mullvad running over wireguard with udp2tcp so it’s compatible with tor
i ran the following in dom0
qvm-firewall sys-vpn reset
qvm-firewall sys-vpn add accept dsthost=1.2.3.4 # (my vpn server's ip)
qvm-firewall sys-vpn del --rule-no 0
however, after disconnecting vpn and running
curl icanhazip.com
i still get my tor exit node ip.
any clue what could be going on?
Firewall rules are applied to a qube’s netvm, and sys-whonix does not support holding firewall rules.
Create a qube providing network from the default-dvm template and add it between sys-whonix and sys-vpn, it will hold the firewall rules.
More information here:
oh my god solene you are so beautiful i love you <3
solved
while you’re here, i’ve another question (although this is quite off topic to this thread)
do you have any clue on why whenever i try making requests on the qubes that sys-vpn provides internet to, nothing goes through EXCEPT for when i (for example on firefox) set my proxy to the one mullvad provides (10.64.0.1)? very odd but i can’t really think of any reason
It sounds like DNS problems to me.
Can you ping 8.8.8.8 but not google.fr ? (pick the domain of your choice)
indeed i can
how can issues with dns only appear on the qubes that internet is being provided to and not the one which provides it?
If you do this and connect any other qubes to that firewall, then there
is a risk of breaking anonymity, because sys-whonix will see all
traffic as originating from the same IP - that of the firewall. This may
be fine for your threat model. Or not.
is there a workaround to this?
Dont connect two qubes to the same firewall.
Dont interject a firewall.
Dont use Whonix.
The easy solution IMO would be to have a firewall qube for the vpn qube, and continue to use sys-whonix as a netvm for all other qubes that need to go through tor but do not need firewall rules.
just now rereading this, and (excuse my weak knowledge of qubes) i’m not quite sure what you mean
by “that firewall”, are you talking about the qube between sys-whonix and sys-vpn?
also, how does sys-whonix seeing traffic originating from the firewall’s ip risk breaking anonymity? in the case of compromise you mean?
yes
Since the firewall masquerades all traffic, the netvms will see all
traffic as originating from the same IP address - this means there is a
risk that streams from different qubes will not be isolated. (Not
obviously a problem for guarding VPN.)
but i suppose that if i use the qube inbetween only with sys-vpn, i’m fine?
Yes. To restrict traffic to the VPN that is a valid use: a single
firewall. (You could, of course, do this in sys-vpn nftables, but a
separate firewall adds a belt. For me, I would make sure that that
qube does not output any traffic.)
