try to upgrade fedora use dom0 upgrade and fail on whonix and direct from network, try in terminal
no work
no work
i am upset
Updating fedora-34
Function: pkg.installed
Result: True
Comment: All specified packages are already installed and are at the desired version
Started: 17:40:52.370847
Duration: 460.898 ms
Changes:
Function: file.absent
Result: True
Comment: File /usr/lib/rpm/macros.d/macros.qubes is not present
Started: 17:40:52.835573
Duration: 0.475 ms
Changes:
Function: cmd.script
Result: False
Comment: Could not create DNF metadata cache
Started: 17:40:52.836747
Duration: 623010.312 ms
Changes:
Function: file.append
Result: True
Comment: File /etc/dnf/dnf.conf is in correct state
Started: 17:51:15.847274
Duration: 1.545 ms
Changes:
Function: pkg.uptodate
Result: False
Comment: One or more requisite failed: update.qubes-vm.dnf-makecache
Started: 17:51:15.849287
Duration: 0.003 ms
Changes:
Function: cmd.run
Result: False
Comment: Command "/usr/lib/qubes/upgrades-status-notify" run
Started: 17:51:15.849326
Duration: 312039.391 ms
Changes:
pid:
1273
retcode:
1
stderr:
Error: Failed to download metadata for repo 'fedora': Cannot prepare internal mirrorlist: Curl error (28): Timeout was reached for https://mirrors.fedoraproject.org/metalink?repo=fedora-34&arch=x86_64 [Operation timed out after 30000 milliseconds with 0 out of 0 bytes received]
stdout:
Total states run: 6
Total run time: 935.513 s
maybe using drugs will help give me a better insightful into why fedora does not upgrade?
ok i am back and feel better
ready for more trying to fix this
iâll first connect all the templates directly to sys-net to see if fixes problem
edit i am not sure if this fixed problem
i am going to connect sys-usb to sys-net to see if this fixes it
i am going to connect to sys-whonix to sys-usb to see if this fixes
it still is not fixed
its still not fixed! @Sven hellllllp!
you simply donât have a net connection. Question is now - how are your qubes put together in your qubes manager and whats your updateVM (sys-whonix or something else)?
Usual way to the net should be:
internet â sys-net â sys-firewall â sys-whonix
---------------------------------------------^â appVMs
Error: Failed to download metadata for repo âfedoraâ: Cannot prepare internal mirrorlist: Curl error (28): Timeout was reached forhttps://mirrors.fedoraproject.org/metalink?repo=fedora-34&arch=x86_64 [Operation timed out after 30000 milliseconds with 0 out of 0 bytes received]
It appears you have no network.
i am posting from the machine that has no internet
it has internet
the internet is connected to sys-net to sys-firewall to sys-whonix
i have global settings to get updates/upgrades from whonix
all the other templates did upgrade
i have no idea whats hapening
If you are on R4.0 please post the contents of /etc/qubes-rpc/policy/qubes.UpdatesProxy
Within the fedora template, please try curl --proxy http://127.0.0.1:8082/ -O https://keys.qubes-os.org/keys/qubes-release-4-signing-key.asc to check the network connection without using dnf
Does sudo dnf update in fedora-34âs terminal works?
If it works, then when using Qubes update to update fedora-34, is default-mgmt-dvm invoked? It might be something wrong with itâŚ
If itâs invoked, does update in itâs terminal works? If it works, then itâs the problem between it and the template. If it doesnât work then the network doesnât work,
If itâs not invoked, then itâs the problem of the template, I guess, and you should maybe try to download and install fresh new template.
EDIT: Sorry, @Sven added post while i was preparing mine, so didnât see it.
$tag:whonix-updatevm $default allow,target=sys-whonix
$tag:whonix-updatevm $anyvm deny
when i did curl in the terminal nothing happened. i saw a bunch of 0s and after a long time shut down the qube
I typed it and it says
Copr repo for PyChar
then itâs a bunch of zeros and lines and nothing happens
I must to download an entire new template?
If those are the only lines you found the problem, make sure you also have the following lines:
$type:TemplateVM $default allow,target=sys-whonix
$type:TemplateVM $anyvm deny
This confirms no connection, which is not surprising if the above lines are in fact the only ones. $tag:whonix-updatevm identifies only qubes that have the respective tag (you can check with qvm-tags). $type:TemplateVM identifies all templates.
i donât think it fixed it
i tried your fix @sven but the cirlce thing goe aroun and around. nothing changes
itâs doing what it did before: just showing âUpdating fedora-34â for a much time with nothing hapening
is there command or icon for qubes to see rate of download upload?
i think itâs doing no thing
does the disp-mgmt need net access or is that qubes that used for just moving files or upgrade around?
i donât like connecting to net through system with possible error and not knowing what goes on
it makes more likely i become crushed under wall
from other posts I assume you are on R4.1?
If so that was the wrong file and has no influence on whatâs happening. I am not on R4.1 yet personally, but here is an article explaining the difference:
You said all your other templates update fine. What are those? Debian, Whonix?
I have never seen such an output from dnf update. Sorry.
