Just face an issue in Qube that run with Fedora distribution kernel, using pvgrub2-pvh.
Last Fedora 43 kernel patch kernel-6.19.10-200 result in qrexec timeout issue, qube can’t start or reboot.
Should I wait for Qubes packages patch? or these is any known troubleshoot process?
according to console and log, 2 services can’t start:
qubes-bind-dirs
qubes-db
P.s.
Switch template/qube back to default qubes kernel solve issue for a while.
Log from one of disp qubes with last Fedora43 kernel.
[2026-03-31 15:18:12] Logfile Opened
[2026-03-31 15:18:12] .[30m.[47mWelcome to GRUB!
[2026-03-31 15:18:12] .[37m.[40m.[37m.[40m.[37m.[40m.[3;34H [ grub-xen.cfg 424B 100% 20.70KiB/s ].[3;1Herror: ../../grub-core/commands/search.c:472:no such device:
[2026-03-31 15:18:12] /boot/xen/pvboot-x86_64.elf.
[2026-03-31 15:18:12] error: ../../grub-core/commands/search.c:472:no such device:
[2026-03-31 15:18:12] /boot/grub/grub.cfg.
[2026-03-31 15:18:12] Reading (xen/xvda,gpt3/boot/grub2/grub.cfg
[2026-03-31 15:18:12] .[H.[J.[1;1H.[1;37H [ grubenv 1.00KiB 100% 1.27KiB/s ].[1;1Herror: ../../grub-core/fs/archelp.c:268:file `/boot/grub/fonts/unicode.pf2' not
[2026-03-31 15:18:12] found.
[2026-03-31 15:18:12] error: ../../grub-core/video/video.c:761:no suitable video mode found.
[2026-03-31 15:18:12] error: ../../grub-core/fs/archelp.c:268:file `/boot/grub/grubenv' not found.
[2026-03-31 15:18:15] [ 0.423850] Run /init as init process
[2026-03-31 15:18:15] .P+q6E616D65.\[ 0.768169] systemd[1]: Successfully made /usr/ read-only.
[2026-03-31 15:18:15] .[6n.[32766;32766H.[6n.[!p.]104.\.[0m.[?7h.[1G.[0J[ 1.101949] systemd[1]: systemd 258.7-1.fc43 running in system mode (+PAM +AUDIT +SELINUX -APPARMOR +IMA +IPE +SMACK +SECCOMP -GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN -IPTC +KMOD +LIBCRYPTSETUP +LIBCRYPTSETUP_PLUGINS +LIBFDISK +PCRE2 +PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +BPF_FRAMEWORK +BTF +XKBCOMMON +UTMP +SYSVINIT +LIBARCHIVE)
[2026-03-31 15:18:16] [ 1.102056] systemd[1]: Detected virtualization xen.
[2026-03-31 15:18:16] [ 1.102091] systemd[1]: Detected architecture x86-64.
[2026-03-31 15:18:16] [ 1.102112] systemd[1]: Running in initrd.
[2026-03-31 15:18:16] .[0;1;39mBooting initrd of .[0m.[0;38;2;60;110;180mFedora Linux 43 (Forty Three) dracut-107-8.fc43 (Initramfs).[0m.[0;1;39m..[0m
[2026-03-31 15:18:16] [ 1.102569] systemd[1]: Initializing machine ID from SMBIOS/DMI UUID.
[2026-03-31 15:18:16] [ 1.102658] systemd[1]: No hostname configured, using default hostname.
[2026-03-31 15:18:16] [ 1.102778] systemd[1]: Hostname set to <fedora>.
[2026-03-31 15:18:16] [.[0;32m OK .[0m] Finished .[0;1;39msystemd-tmpfiles-setup-de….[0mic Device Nodes in /dev gracefully.
[2026-03-31 15:18:16] [ 1.360079] i2c_dev: i2c /dev entries driver
[2026-03-31 15:18:16] [ 1.361788] systemd[1]: Starting systemd-sysusers.service - Create System Users...
[2026-03-31 15:18:16] Starting .[0;1;39msystemd-sysusers.service.[0m - Create System Users...
[2026-03-31 15:18:16] [ 1.364626] xen:xen_evtchn: Event-channel device installed
[2026-03-31 15:18:16] [ 1.370308] systemd[1]: Finished dracut-cmdline-ask.service - dracut ask for additional cmdline parameters.
[2026-03-31 15:18:16] [.[0;32m OK .[0m] Finished .[0;1;39mdracut-cmdline-ask.servic….[0m for additional cmdline parameters.
[2026-03-31 15:18:16] [ 1.537269] systemd[1]: Finished systemd-sysusers.service - Create System Users.
[2026-03-31 15:18:16] [.[0;32m OK .[0m] Finished .[0;1;39msystemd-sysusers.service.[0m - Create System Users.
[2026-03-31 15:18:16] [ 1.538798] systemd[1]: Starting dracut-cmdline.service - dracut cmdline hook...
[2026-03-31 15:18:16] Starting .[0;1;39mdracut-cmdline.service.[0m - dracut cmdline hook...
[2026-03-31 15:18:16] [ 1.539351] systemd[1]: Starting systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev...
[2026-03-31 15:18:16] Starting .[0;1;39msystemd-tmpfiles-setup-de….[0meate Static Device Nodes in /dev...
[2026-03-31 15:18:16] [ 1.550071] xen:xen_privcmd: No target domain found, blocking all hypercalls
[2026-03-31 15:18:16] [ 1.550280] systemd[1]: Finished systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev.
[2026-03-31 15:18:16] [.[0;32m OK .[0m] Finished .[0;1;39msystemd-tmpfiles-setup-de….[0mCreate Static Device Nodes in /dev.
[2026-03-31 15:18:16] [ 1.550467] systemd[1]: Reached target local-fs-pre.target - Preparation for Local File Systems.
[2026-03-31 15:18:16] [.[0;32m OK .[0m] Reached target .[0;1;39mlocal-fs-pre.target.[0m…Preparation for Local File Systems.
[2026-03-31 15:18:16] [ 1.550546] systemd[1]: Reached target local-fs.target - Local File Systems.
[2026-03-31 15:18:16] [.[0;32m OK .[0m] Reached target .[0;1;39mlocal-fs.target.[0m - Local File Systems.
[2026-03-31 15:18:16] [ 1.551485] systemd[1]: Started haveged.service - Entropy Daemon based on the HAVEGE algorithm.
[2026-03-31 15:18:16] [.[0;32m OK .[0m] Started .[0;1;39mhaveged.service.[0m - Entropy …emon based on the HAVEGE algorithm.
[2026-03-31 15:18:16] [ 1.554786] systemd[1]: Starting systemd-journald.service - Journal Service...
[2026-03-31 15:18:16] Starting .[0;1;39msystemd-journald.service.[0m - Journal Service...
[2026-03-31 15:18:16] [ 1.597936] systemd-journald[220]: Collecting audit messages is disabled.
[2026-03-31 15:18:16] [ 1.606233] systemd[1]: Started systemd-journald.service - Journal Service.
[2026-03-31 15:18:16] [.[0;32m OK .[0m] Started .[0;1;39msystemd-journald.service.[0m - Journal Service.
[2026-03-31 15:18:16] Starting .[0;1;39msystemd-tmpfiles-setup.se….[0mate System Files and Directories...
[2026-03-31 15:18:16] [.[0;32m OK .[0m] Finished .[0;1;39msystemd-tmpfiles-setup.se….[0mreate System Files and Directories.
[2026-03-31 15:18:16] [.[0;32m OK .[0m] Finished .[0;1;39mdracut-cmdline.service.[0m - dracut cmdline hook.
[2026-03-31 15:18:16] Starting .[0;1;39mdracut-pre-udev.service.[0m - dracut pre-udev hook...
[2026-03-31 15:18:16] [ 1.758969] Rounding down aligned max_sectors from 4294967295 to 4294967288
[2026-03-31 15:18:16] [ 1.759149] db_root: cannot open: /etc/target
[2026-03-31 15:18:16] [.[0;32m OK .[0m] Finished .[0;1;39msystemd-modules-load.service.[0m - Load Kernel Modules.
[2026-03-31 15:18:16] Starting .[0;1;39msystemd-sysctl.service.[0m - Apply Kernel Variables...
[2026-03-31 15:18:16] [.[0;32m OK .[0m] Finished .[0;1;39msystemd-sysctl.service.[0m - Apply Kernel Variables.
[2026-03-31 15:18:16] [.[0;32m OK .[0m] Finished .[0;1;39mdracut-pre-udev.service.[0m - dracut pre-udev hook.
[2026-03-31 15:18:16] Starting .[0;1;39msystemd-udevd.service.[0m - R…ager for Device Events and Files...
[2026-03-31 15:18:16] [.[0;32m OK .[0m] Started .[0;1;39msystemd-udevd.service.[0m - Ru…anager for Device Events and Files.
[2026-03-31 15:18:16] Starting .[0;1;39mdracut-pre-trigger.service.[0m - dracut pre-trigger hook...
[2026-03-31 15:18:16] [ 1.931824] Invalid max_queues (4), will use default max: 2.
[2026-03-31 15:18:16] [ 1.938933] blkfront: xvda: flush diskcache: enabled; persistent grants: enabled; indirect descriptors: enabled; bounce buffer: enabled
[2026-03-31 15:18:16] [ 1.941756] xvda: xvda1 xvda2 xvda3
[2026-03-31 15:18:16] [ 1.944393] blkfront: xvdb: flush diskcache: enabled; persistent grants: enabled; indirect descriptors: enabled; bounce buffer: enabled
[2026-03-31 15:18:16] [ 1.949637] blkfront: xvdc: flush diskcache: enabled; persistent grants: enabled; indirect descriptors: enabled; bounce buffer: enabled
[2026-03-31 15:18:17] [ 2.323021] xvdc: xvdc1 xvdc3
[2026-03-31 15:18:17] [ 2.337770] Adding 1048572k swap on /dev/xvdc1. Priority:-1 extents:1 across:1048572k SS
[.[0;32m OK .[0m] Finished .[0;1;39mdracut-pre-trigger.service.[0m - dracut pre-trigger hook.
[2026-03-31 15:18:17] Starting .[0;1;39msystemd-udev-trigger.service.[0m - Coldplug All udev Devices...
[2026-03-31 15:18:17] [.[0;32m OK .[0m] Finished .[0;1;39msystemd-udev-trigger.service.[0m - Coldplug All udev Devices.
[2026-03-31 15:18:17] [.[0;32m OK .[0m] Reached target .[0;1;39msysinit.target.[0m - System Initialization.
[2026-03-31 15:18:17] [.[0;32m OK .[0m] Reached target .[0;1;39mbasic.target.[0m - Basic System.
[2026-03-31 15:18:17] [.[0;32m OK .[0m] Reached target .[0;1;39mremote-fs-pre.targe….[0mreparation for Remote File Systems.
[2026-03-31 15:18:17] [.[0;32m OK .[0m] Reached target .[0;1;39mremote-fs.target.[0m - Remote File Systems.
[2026-03-31 15:18:17] Starting .[0;1;39mdracut-pre-mount.service.[0m - dracut pre-mount hook...
[2026-03-31 15:18:17] [.[0;32m OK .[0m] Finished .[0;1;39mdracut-pre-mount.service.[0m - dracut pre-mount hook.
[2026-03-31 15:18:17] [.[0;32m OK .[0m] Found device .[0;1;39mdev-mapper-dmroot.device.[0m - /dev/mapper/dmroot.
[2026-03-31 15:18:17] [.[0;32m OK .[0m] Reached target .[0;1;39minitrd-root-device.target.[0m - Initrd Root Device.
[2026-03-31 15:18:17] Starting .[0;1;39msystemd-fsck-root.service.[0m…stem Check on /dev/mapper/dmroot...
[2026-03-31 15:18:17] [.[0;32m OK .[0m] Created slice .[0;1;39msystem-modprobe.slice.[0m - Slice /system/modprobe.
[2026-03-31 15:18:17] Mounting .[0;1;39msys-kernel-config.mount.[0m - Kernel Configuration File System...
[2026-03-31 15:18:17] [.[0;32m OK .[0m] Mounted .[0;1;39msys-kernel-config.mount.[0m - Kernel Configuration File System.
[2026-03-31 15:18:17] [.[0;32m OK .[0m] Finished .[0;1;39msystemd-fsck-root.service.[0m…System Check on /dev/mapper/dmroot.
[2026-03-31 15:18:17] Mounting .[0;1;39msysroot.mount.[0m - /sysroot...
[2026-03-31 15:18:17] [ 2.751575] EXT4-fs (xvda3): orphan cleanup on readonly fs
[2026-03-31 15:18:17] [ 2.752218] EXT4-fs (xvda3): mounted filesystem 951b6318-f030-4691-9e66-b3a463c9c6b2 ro with ordered data mode. Quota mode: none.
[2026-03-31 15:18:17] [.[0;32m OK .[0m] Mounted .[0;1;39msysroot.mount.[0m - /sysroot.
[2026-03-31 15:18:17] [.[0;32m OK .[0m] Reached target .[0;1;39minitrd-root-fs.target.[0m - Initrd Root File System.
[2026-03-31 15:18:17] Starting .[0;1;39minitrd-parse-etc.service.[0m …ints Configured in the Real Root...
[2026-03-31 15:18:17] [.[0;32m OK .[0m] Finished .[0;1;39minitrd-parse-etc.service.[0m …points Configured in the Real Root.
[2026-03-31 15:18:17] [.[0;32m OK .[0m] Reached target .[0;1;39minitrd-fs.target.[0m - Initrd File Systems.
[2026-03-31 15:18:17] [.[0;32m OK .[0m] Reached target .[0;1;39minitrd.target.[0m - Initrd Default Target.
[2026-03-31 15:18:17] Starting .[0;1;39mdracut-pre-pivot.service.[0m …racut pre-pivot and cleanup hook...
[2026-03-31 15:18:17] [.[0;32m OK .[0m] Finished .[0;1;39mdracut-pre-pivot.service.[0m - dracut pre-pivot and cleanup hook.
[2026-03-31 15:18:17] Starting .[0;1;39minitrd-cleanup.service.[0m - …ing Up and Shutting Down Daemons...
[2026-03-31 15:18:17] [.[0;32m OK .[0m] Stopped target .[0;1;39mtimers.target.[0m - Timer Units.
[2026-03-31 15:18:17] [.[0;32m OK .[0m] Stopped .[0;1;39mdracut-pre-pivot.service.[0m - dracut pre-pivot and cleanup hook.
[2026-03-31 15:18:17] [.[0;32m OK .[0m] Stopped target .[0;1;39minitrd.target.[0m - Initrd Default Target.
[2026-03-31 15:18:17] [.[0;32m OK .[0m] Stopped target .[0;1;39mbasic.target.[0m - Basic System.
[2026-03-31 15:18:17] [.[0;32m OK .[0m] Stopped target .[0;1;39minitrd-root-device.target.[0m - Initrd Root Device.
[2026-03-31 15:18:17] [.[0;32m OK .[0m] Stopped target .[0;1;39minitrd-usr-fs.target.[0m - Initrd /usr File System.
[2026-03-31 15:18:17] [.[0;32m OK .[0m] Stopped target .[0;1;39mpaths.target.[0m - Path Units.
[2026-03-31 15:18:17] [.[0;32m OK .[0m] Stopped .[0;1;39msystemd-ask-password-conso….[0mequests to Console Directory Watch.
[2026-03-31 15:18:17] [.[0;32m OK .[0m] Stopped target .[0;1;39mremote-fs.target.[0m - Remote File Systems.
[2026-03-31 15:18:17] [.[0;32m OK .[0m] Stopped target .[0;1;39mremote-fs-pre.targe….[0mreparation for Remote File Systems.
[2026-03-31 15:18:17] [.[0;32m OK .[0m] Stopped target .[0;1;39mslices.target.[0m - Slice Units.
[2026-03-31 15:18:17] [.[0;32m OK .[0m] Stopped target .[0;1;39msockets.target.[0m - Socket Units.
[2026-03-31 15:18:17] [.[0;32m OK .[0m] Stopped target .[0;1;39msysinit.target.[0m - System Initialization.
[2026-03-31 15:18:17] [.[0;32m OK .[0m] Stopped target .[0;1;39mswap.target.[0m - Swaps.
[2026-03-31 15:18:17] [.[0;32m OK .[0m] Stopped .[0;1;39mdracut-pre-mount.service.[0m - dracut pre-mount hook.
[2026-03-31 15:18:17] Starting .[0;1;39mhaveged-switch-root.service.[0m - Tell haveged about new root...
[2026-03-31 15:18:17] [.[0;32m OK .[0m] Stopped .[0;1;39msystemd-sysctl.service.[0m - Apply Kernel Variables.
[2026-03-31 15:18:17] [.[0;32m OK .[0m] Stopped .[0;1;39msystemd-modules-load.service.[0m - Load Kernel Modules.
[2026-03-31 15:18:17] [.[0;32m OK .[0m] Stopped .[0;1;39msystemd-tmpfiles-setup.ser….[0mreate System Files and Directories.
[2026-03-31 15:18:17] [.[0;32m OK .[0m] Stopped target .[0;1;39mlocal-fs.target.[0m - Local File Systems.
[2026-03-31 15:18:17] [.[0;32m OK .[0m] Stopped target .[0;1;39mlocal-fs-pre.target.[0m…Preparation for Local File Systems.
[2026-03-31 15:18:17] [.[0;32m OK .[0m] Stopped .[0;1;39msystemd-udev-trigger.service.[0m - Coldplug All udev Devices.
[2026-03-31 15:18:17] [.[0;32m OK .[0m] Stopped .[0;1;39mdracut-pre-trigger.service.[0m - dracut pre-trigger hook.
[2026-03-31 15:18:17] Stopping .[0;1;39msystemd-udevd.service.[0m - R…ager for Device Events and Files...
[2026-03-31 15:18:17] [.[0;32m OK .[0m] Finished .[0;1;39minitrd-cleanup.service.[0m - …aning Up and Shutting Down Daemons.
[2026-03-31 15:18:17] [.[0;32m OK .[0m] Stopped .[0;1;39msystemd-udevd.service.[0m - Ru…anager for Device Events and Files.
[2026-03-31 15:18:17] [.[0;32m OK .[0m] Closed .[0;1;39msystemd-udevd-control.socket.[0m - udev Control Socket.
[2026-03-31 15:18:17] [.[0;32m OK .[0m] Stopped .[0;1;39mdracut-pre-udev.service.[0m - dracut pre-udev hook.
[2026-03-31 15:18:17] [.[0;32m OK .[0m] Stopped .[0;1;39mdracut-cmdline.service.[0m - dracut cmdline hook.
[2026-03-31 15:18:17] [.[0;32m OK .[0m] Stopped .[0;1;39mdracut-cmdline-ask.service.[0m… for additional cmdline parameters.
[2026-03-31 15:18:17] Starting .[0;1;39minitrd-udevadm-cleanup-db.service.[0m - Cleanup udev Database...
[2026-03-31 15:18:17] [.[0;32m OK .[0m] Stopped .[0;1;39msystemd-tmpfiles-setup-dev….[0mCreate Static Device Nodes in /dev.
[2026-03-31 15:18:17] [.[0;32m OK .[0m] Stopped .[0;1;39msystemd-sysusers.service.[0m - Create System Users.
[2026-03-31 15:18:17] [.[0;32m OK .[0m] Stopped .[0;1;39msystemd-tmpfiles-setup-dev….[0mic Device Nodes in /dev gracefully.
[2026-03-31 15:18:17] [.[0;32m OK .[0m] Stopped .[0;1;39mkmod-static-nodes.service.[0m …Create List of Static Device Nodes.
[2026-03-31 15:18:17] [.[0;32m OK .[0m] Finished .[0;1;39mhaveged-switch-root.service.[0m - Tell haveged about new root.
[2026-03-31 15:18:17] [.[0;32m OK .[0m] Finished .[0;1;39minitrd-udevadm-cleanup-db.service.[0m - Cleanup udev Database.
[2026-03-31 15:18:17] [.[0;32m OK .[0m] Reached target .[0;1;39minitrd-switch-root.target.[0m - Switch Root.
[2026-03-31 15:18:17] Starting .[0;1;39minitrd-switch-root.service.[0m - Switch Root...
[2026-03-31 15:18:17] [ 3.022589] systemd-journald[220]: Received SIGTERM from PID 1 (systemd).
[2026-03-31 15:18:18] [ 3.087135] audit: type=1404 audit(1774959497.892:2): enforcing=1 old_enforcing=0 auid=4294967295 ses=4294967295 enabled=1 old-enabled=1 lsm=selinux res=1
[2026-03-31 15:18:18] [ 3.121570] SELinux: Permission firmware_load in class system not defined in policy.
[2026-03-31 15:18:18] [ 3.121609] SELinux: Permission kexec_image_load in class system not defined in policy.
[2026-03-31 15:18:18] [ 3.121631] SELinux: Permission kexec_initramfs_load in class system not defined in policy.
[2026-03-31 15:18:18] [ 3.121655] SELinux: Permission policy_load in class system not defined in policy.
[2026-03-31 15:18:18] [ 3.121688] SELinux: Permission x509_certificate_load in class system not defined in policy.
[2026-03-31 15:18:18] [ 3.121795] SELinux: Permission allowed in class io_uring not defined in policy.
[2026-03-31 15:18:18] [ 3.121820] SELinux: Class memfd_file not defined in policy.
[2026-03-31 15:18:18] [ 3.121838] SELinux: the above unknown classes and permissions will be allowed
[2026-03-31 15:18:18] [ 3.125089] SELinux: policy capability network_peer_controls=1
[2026-03-31 15:18:18] [ 3.125121] SELinux: policy capability open_perms=1
[2026-03-31 15:18:18] [ 3.125136] SELinux: policy capability extended_socket_class=1
[2026-03-31 15:18:18] [ 3.125154] SELinux: policy capability always_check_network=0
[2026-03-31 15:18:18] [ 3.125173] SELinux: policy capability cgroup_seclabel=1
[2026-03-31 15:18:18] [ 3.125188] SELinux: policy capability nnp_nosuid_transition=1
[2026-03-31 15:18:18] [ 3.125207] SELinux: policy capability genfs_seclabel_symlinks=1
[2026-03-31 15:18:18] [ 3.125224] SELinux: policy capability ioctl_skip_cloexec=0
[2026-03-31 15:18:18] [ 3.125242] SELinux: policy capability userspace_initial_context=0
[2026-03-31 15:18:18] [ 3.125260] SELinux: policy capability netlink_xperm=0
[2026-03-31 15:18:18] [ 3.125274] SELinux: policy capability netif_wildcard=0
[2026-03-31 15:18:18] [ 3.125289] SELinux: policy capability genfs_seclabel_wildcard=0
[2026-03-31 15:18:18] [ 3.125307] SELinux: policy capability functionfs_seclabel=0
[2026-03-31 15:18:18] [ 3.125326] SELinux: policy capability memfd_class=0
[2026-03-31 15:18:18] [ 3.165866] audit: type=1403 audit(1774959497.970:3): auid=4294967295 ses=4294967295 lsm=selinux res=1
[2026-03-31 15:18:18] [ 3.166836] systemd[1]: Successfully loaded SELinux policy in 80.076ms.
[2026-03-31 15:18:18] .P+q6E616D65.\[2026-03-31 15:18:18] [ 3.533186] systemd[1]: Relabeled /dev/, /dev/shm/, /run/ in 10.842ms.
[2026-03-31 15:18:18] .[6n.[32766;32766H.[6n.[!p.]104.\.[0m.[?7h.[1G.[0J[ 3.871326] systemd[1]: systemd 258.7-1.fc43 running in system mode (+PAM +AUDIT +SELINUX -APPARMOR +IMA +IPE +SMACK +SECCOMP -GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN -IPTC +KMOD +LIBCRYPTSETUP +LIBCRYPTSETUP_PLUGINS +LIBFDISK +PCRE2 +PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +BPF_FRAMEWORK +BTF +XKBCOMMON +UTMP +SYSVINIT +LIBARCHIVE)
[2026-03-31 15:18:18] [ 3.871427] systemd[1]: Detected virtualization xen.
[2026-03-31 15:18:18] [ 3.871463] systemd[1]: Detected architecture x86-64.
[2026-03-31 15:18:18] .[0;1;39mWelcome to .[0m.[0;38;2;60;110;180mFedora Linux 43 (Forty Three).[0m.[0;1;39m!.[0m
[2026-03-31 15:18:18] .]3008;start=eb060ae632a94fa0b00c6d0c653646ff;user=root;hostname=fedora;machineid=acd7953b537c49a9b20dd543531fd2e2;bootid=acd101feb23148d9842d1190961da4bc;pid=1;pidfdid=2;comm=systemd;type=boot.\[ 3.980960] systemd[1]: bpf-restrict-fs: LSM BPF program attached
[ 4.257132] systemd[1]: initrd-switch-root.service: Deactivated successfully.
[2026-03-31 15:18:19] [ 4.257349] systemd[1]: Stopped initrd-switch-root.service - Switch Root.
[2026-03-31 15:18:19] [.[0;32m OK .[0m] Stopped .[0;1;39minitrd-switch-root.service.[0m - Switch Root.
[2026-03-31 15:18:19] [ 4.258566] systemd[1]: systemd-journald.service: Scheduled restart job, restart counter is at 1.
[2026-03-31 15:18:19] [ 4.259257] systemd[1]: Created slice system-getty.slice - Slice /system/getty.
[2026-03-31 15:18:19] [.[0;32m OK .[0m] Created slice .[0;1;39msystem-getty.slice.[0m - Slice /system/getty.
[2026-03-31 15:18:19] [ 4.259651] systemd[1]: Created slice system-serial\x2dgetty.slice - Slice /system/serial-getty.
[2026-03-31 15:18:19] [.[0;32m OK .[0m] Created slice .[0;1;39msystem-serial\x2dget…slice.[0m - Slice /system/serial-getty.
[2026-03-31 15:18:19] [ 4.260112] systemd[1]: Created slice system-systemd\x2dfsck.slice - Slice /system/systemd-fsck.
[2026-03-31 15:18:19] [.[0;32m OK .[0m] Created slice .[0;1;39msystem-systemd\x2dfs…slice.[0m - Slice /system/systemd-fsck.
[2026-03-31 15:18:19] [ 4.260433] systemd[1]: Created slice user.slice - User and Session Slice.
[2026-03-31 15:18:19] [.[0;32m OK .[0m] Created slice .[0;1;39muser.slice.[0m - User and Session Slice.
[2026-03-31 15:18:19] [ 4.260592] systemd[1]: Started systemd-ask-password-console.path - Dispatch Password Requests to Console Directory Watch.
[2026-03-31 15:18:19] [.[0;32m OK .[0m] Started .[0;1;39msystemd-ask-password-conso….[0mequests to Console Directory Watch.
[2026-03-31 15:18:19] [ 4.260729] systemd[1]: Started systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch.
[2026-03-31 15:18:19] [.[0;32m OK .[0m] Started .[0;1;39msystemd-ask-password-wall.….[0md Requests to Wall Directory Watch.
[2026-03-31 15:18:19] [ 4.261144] systemd[1]: Set up automount proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point.
[2026-03-31 15:18:19] [.[0;32m OK .[0m] Set up automount .[0;1;39mproc-sys-fs-binfm….[0mormats File System Automount Point.
[2026-03-31 15:18:19] [ 4.261252] systemd[1]: Expecting device dev-hvc0.device - /dev/hvc0...
[2026-03-31 15:18:19] Expecting device .[0;1;39mdev-hvc0.device.[0m - /dev/hvc0...
[2026-03-31 15:18:19] [ 4.261319] systemd[1]: Expecting device dev-xvdb.device - /dev/xvdb...
[2026-03-31 15:18:19] Expecting device .[0;1;39mdev-xvdb.device.[0m - /dev/xvdb...
[2026-03-31 15:18:19] [ 4.261384] systemd[1]: Reached target cryptsetup.target - Local Encrypted Volumes.
[2026-03-31 15:18:19] [.[0;32m OK .[0m] Reached target .[0;1;39mcryptsetup.target.[0m - Local Encrypted Volumes.
[2026-03-31 15:18:19] [ 4.261453] systemd[1]: Reached target imports.target - Image Downloads.
[2026-03-31 15:18:19] [.[0;32m OK .[0m] Reached target .[0;1;39mimports.target.[0m - Image Downloads.
[2026-03-31 15:18:19] [ 4.261523] systemd[1]: Stopped target initrd-switch-root.target - Switch Root.
[2026-03-31 15:18:19] [.[0;32m OK .[0m] Stopped target .[0;1;39minitrd-switch-root.target.[0m - Switch Root.
[2026-03-31 15:18:19] [ 4.261590] systemd[1]: Stopped target initrd-fs.target - Initrd File Systems.
[2026-03-31 15:18:19] [.[0;32m OK .[0m] Stopped target .[0;1;39minitrd-fs.target.[0m - Initrd File Systems.
[2026-03-31 15:18:19] [ 4.261650] systemd[1]: Stopped target initrd-root-fs.target - Initrd Root File System.
[2026-03-31 15:18:19] [.[0;32m OK .[0m] Stopped target .[0;1;39minitrd-root-fs.target.[0m - Initrd Root File System.
[2026-03-31 15:18:19] [ 4.261747] systemd[1]: Reached target integritysetup.target - Local Integrity Protected Volumes.
[2026-03-31 15:18:19] [.[0;32m OK .[0m] Reached target .[0;1;39mintegritysetup.targ….[0m Local Integrity Protected Volumes.
[2026-03-31 15:18:19] [ 4.261829] systemd[1]: Reached target paths.target - Path Units.
[2026-03-31 15:18:19] [.[0;32m OK .[0m] Reached target .[0;1;39mpaths.target.[0m - Path Units.
[2026-03-31 15:18:19] [ 4.261894] systemd[1]: Reached target remote-fs.target - Remote File Systems.
[2026-03-31 15:18:19] [.[0;32m OK .[0m] Reached target .[0;1;39mremote-fs.target.[0m - Remote File Systems.
[2026-03-31 15:18:19] [ 4.261957] systemd[1]: Reached target slices.target - Slice Units.
[2026-03-31 15:18:19] [.[0;32m OK .[0m] Reached target .[0;1;39mslices.target.[0m - Slice Units.
[2026-03-31 15:18:19] [ 4.262023] systemd[1]: Reached target swap.target - Swaps.
[2026-03-31 15:18:19] [.[0;32m OK .[0m] Reached target .[0;1;39mswap.target.[0m - Swaps.
[2026-03-31 15:18:19] [ 4.262092] systemd[1]: Reached target veritysetup.target - Local Verity Protected Volumes.
[2026-03-31 15:18:19] [.[0;32m OK .[0m] Reached target .[0;1;39mveritysetup.target.[0m - Local Verity Protected Volumes.
[2026-03-31 15:18:19] [ 4.358959] systemd[1]: Listening on systemd-ask-password.socket - Query the User Interactively for a Password.
[2026-03-31 15:18:19] [.[0;32m OK .[0m] Listening on .[0;1;39msystemd-ask-password.….[0m User Interactively for a Password.
[2026-03-31 15:18:19] [ 4.361657] systemd[1]: Listening on systemd-coredump.socket - Process Core Dump Socket.
[2026-03-31 15:18:19] [.[0;32m OK .[0m] Listening on .[0;1;39msystemd-coredump.socket.[0m - Process Core Dump Socket.
[2026-03-31 15:18:19] [ 4.363554] systemd[1]: Listening on systemd-creds.socket - Credential Encryption/Decryption.
[2026-03-31 15:18:19] [.[0;32m OK .[0m] Listening on .[0;1;39msystemd-creds.socket.[0m - Credential Encryption/Decryption.
[2026-03-31 15:18:19] [ 4.365391] systemd[1]: Listening on systemd-factory-reset.socket - Factory Reset Management.
[2026-03-31 15:18:19] [.[0;32m OK .[0m] Listening on .[0;1;39msystemd-factory-reset.socket.[0m - Factory Reset Management.
[2026-03-31 15:18:19] [ 4.365899] systemd[1]: Listening on systemd-journald-audit.socket - Journal Audit Socket.
[2026-03-31 15:18:19] [.[0;32m OK .[0m] Listening on .[0;1;39msystemd-journald-audit.socket.[0m - Journal Audit Socket.
[2026-03-31 15:18:19] [ 4.366016] systemd[1]: systemd-pcrextend.socket - TPM PCR Measurements skipped, unmet condition check ConditionSecurity=measured-uki
[2026-03-31 15:18:19] [ 4.366066] systemd[1]: systemd-pcrlock.socket - Make TPM PCR Policy skipped, unmet condition check ConditionSecurity=measured-uki
[2026-03-31 15:18:19] [ 4.366414] systemd[1]: Listening on systemd-resolved-monitor.socket - Resolve Monitor Varlink Socket.
[2026-03-31 15:18:19] [.[0;32m OK .[0m] Listening on .[0;1;39msystemd-resolved-moni…t.[0m - Resolve Monitor Varlink Socket.
[2026-03-31 15:18:19] [ 4.366613] systemd[1]: Listening on systemd-resolved-varlink.socket - Resolve Service Varlink Socket.
[2026-03-31 15:18:19] [.[0;32m OK .[0m] Listening on .[0;1;39msystemd-resolved-varl…t.[0m - Resolve Service Varlink Socket.
[2026-03-31 15:18:19] [ 4.368115] systemd[1]: Listening on systemd-udevd-control.socket - udev Control Socket.
[2026-03-31 15:18:19] [.[0;32m OK .[0m] Listening on .[0;1;39msystemd-udevd-control.socket.[0m - udev Control Socket.
[2026-03-31 15:18:19] [ 4.368430] systemd[1]: Listening on systemd-udevd-varlink.socket - udev Varlink Socket.
[2026-03-31 15:18:19] [.[0;32m OK .[0m] Listening on .[0;1;39msystemd-udevd-varlink.socket.[0m - udev Varlink Socket.
[2026-03-31 15:18:19] [ 4.370331] systemd[1]: Mounting dev-hugepages.mount - Huge Pages File System...
[2026-03-31 15:18:19] Mounting .[0;1;39mdev-hugepages.mount.[0m - Huge Pages File System...
[2026-03-31 15:18:19] [ 4.371351] systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System...
[2026-03-31 15:18:19] Mounting .[0;1;39mdev-mqueue.mount.[0m - POSIX Message Queue File System...
[2026-03-31 15:18:19] [ 4.374772] systemd[1]: Mounting sys-kernel-debug.mount - Kernel Debug File System...
[2026-03-31 15:18:19] Mounting .[0;1;39msys-kernel-debug.mount.[0m - Kernel Debug File System...
[2026-03-31 15:18:19] [ 4.375706] systemd[1]: Mounting sys-kernel-tracing.mount - Kernel Trace File System...
[2026-03-31 15:18:19] Mounting .[0;1;39msys-kernel-tracing.mount.[0m - Kernel Trace File System...
[2026-03-31 15:18:19] [ 4.378909] systemd[1]: Mounting tmp.mount - Temporary Directory /tmp...
[2026-03-31 15:18:19] Mounting .[0;1;39mtmp.mount.[0m - Temporary Directory /tmp...
[2026-03-31 15:18:19] [ 4.380478] systemd[1]: Starting dev-xvdc1-swap.service - Enable swap on /dev/xvdc1 early...
[2026-03-31 15:18:19] Starting .[0;1;39mdev-xvdc1-swap.service.[0m - Enable swap on /dev/xvdc1 early...
[2026-03-31 15:18:19] [ 4.380625] systemd[1]: fips-crypto-policy-overlay.service - Bind-mount FIPS crypto-policy in FIPS mode skipped, unmet condition check ConditionKernelCommandLine=fips=1
[2026-03-31 15:18:19] [ 4.383484] systemd[1]: Starting kmod-static-nodes.service - Create List of Static Device Nodes...
[2026-03-31 15:18:19] Starting .[0;1;39mkmod-static-nodes.service.[0m…eate List of Static Device Nodes...
[2026-03-31 15:18:19] [ 4.383624] systemd[1]: modprobe@configfs.service - Load Kernel Module configfs skipped, unmet condition check ConditionKernelModuleLoaded=!configfs
[2026-03-31 15:18:19] [ 4.383728] systemd[1]: modprobe@dm_mod.service - Load Kernel Module dm_mod skipped, unmet condition check ConditionKernelModuleLoaded=!dm_mod
[2026-03-31 15:18:19] [ 4.383796] systemd[1]: modprobe@drm.service - Load Kernel Module drm skipped, unmet condition check ConditionKernelModuleLoaded=!drm
[2026-03-31 15:18:19] [ 4.386743] systemd[1]: Starting modprobe@fuse.service - Load Kernel Module fuse...
[2026-03-31 15:18:19] Starting .[0;1;39mmodprobe@fuse.service.[0m - Load Kernel Module fuse...
[2026-03-31 15:18:19] [ 4.394127] systemd[1]: Starting modprobe@loop.service - Load Kernel Module loop...
[2026-03-31 15:18:19] Starting .[0;1;39mmodprobe@loop.service.[0m - Load Kernel Module loop...
[2026-03-31 15:18:19] [ 4.396142] systemd[1]: systemd-boot-clear-sysfail.service - Clear SysFail Entry If The Boot Is Successful skipped, unmet condition check ConditionPathExists=/sys/firmware/efi/efivars/LoaderEntrySysFail-4a67b082-0a4c-41cf-b6c7-440b29bb8c4f
[2026-03-31 15:18:19] [ 4.556901] systemd[1]: systemd-hibernate-clear.service - Clear Stale Hibernate Storage Info skipped, unmet condition check ConditionPathExists=/sys/firmware/efi/efivars/HibernateLocation-8cf2644b-4b0b-428f-9387-6d876050dc67
[2026-03-31 15:18:19] [ 4.565768] systemd[1]: Starting systemd-journald.service - Journal Service...
[2026-03-31 15:18:19] Starting .[0;1;39msystemd-journald.service.[0m - Journal Service...
[2026-03-31 15:18:19] [ 4.572772] systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules...
[2026-03-31 15:18:19] Starting .[0;1;39msystemd-modules-load.service.[0m - Load Kernel Modules...
[2026-03-31 15:18:19] [ 4.575819] systemd[1]: Starting systemd-network-generator.service - Generate Network Units from Kernel Command Line...
[2026-03-31 15:18:19] [ 4.576719] loop: module loaded
[2026-03-31 15:18:19] Starting .[0;1;39msystemd-network-generator….[0mk Units from Kernel Command Line...
[2026-03-31 15:18:19] [ 4.577732] systemd[1]: systemd-pcrmachine.service - TPM PCR Machine ID Measurement skipped, unmet condition check ConditionSecurity=measured-uki
[2026-03-31 15:18:19] [ 4.578241] fuse: init (API version 7.45)
[2026-03-31 15:18:19] [ 4.581908] systemd[1]: Starting systemd-remount-fs.service - Remount Root and Kernel File Systems...
[2026-03-31 15:18:19] Starting .[0;1;39msystemd-remount-fs.servic….[0munt Root and Kernel File Systems...
[2026-03-31 15:18:19] [ 4.582003] systemd[1]: systemd-tpm2-setup-early.service - Early TPM SRK Setup skipped, unmet condition check ConditionSecurity=measured-uki
[2026-03-31 15:18:19] [ 4.582519] systemd[1]: Starting systemd-udev-load-credentials.service - Load udev Rules from Credentials...
[2026-03-31 15:18:19] Starting .[0;1;39msystemd-udev-load-credent….[0mLoad udev Rules from Credentials...
[2026-03-31 15:18:19] [ 4.586290] systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices...
[2026-03-31 15:18:19] Starting .[0;1;39msystemd-udev-trigger.service.[0m - Coldplug All udev Devices...
[2026-03-31 15:18:19] [ 4.588613] systemd[1]: Mounted dev-hugepages.mount - Huge Pages File System.
[2026-03-31 15:18:19] [.[0;32m OK .[0m] Mounted .[0;1;39mdev-hugepages.mount.[0m - Huge Pages File System.
[2026-03-31 15:18:19] [ 4.594551] systemd[1]: Mounted dev-mqueue.mount - POSIX Message Queue File System.
[2026-03-31 15:18:19] [.[0;32m OK .[0m] Mounted .[0;1;39mdev-mqueue.mount.[0m - POSIX Message Queue File System.
[2026-03-31 15:18:19] [ 4.594813] systemd[1]: Mounted sys-kernel-debug.mount - Kernel Debug File System.
[2026-03-31 15:18:19] [.[0;32m OK .[0m] Mounted .[0;1;39msys-kernel-debug.mount.[0m - Kernel Debug File System.
[2026-03-31 15:18:19] [ 4.595614] systemd[1]: Mounted sys-kernel-tracing.mount - Kernel Trace File System.
[2026-03-31 15:18:19] [.[0;32m OK .[0m] Mounted .[0;1;39msys-kernel-tracing.mount.[0m - Kernel Trace File System.
[2026-03-31 15:18:19] [ 4.595822] systemd[1]: Mounted tmp.mount - Temporary Directory /tmp.
[2026-03-31 15:18:19] [.[0;32m OK .[0m] Mounted .[0;1;39mtmp.mount.[0m - Temporary Directory /tmp.
[2026-03-31 15:18:19] [ 4.596087] systemd[1]: dev-xvdc1-swap.service: Deactivated successfully.
[2026-03-31 15:18:19] [ 4.596210] systemd[1]: Finished dev-xvdc1-swap.service - Enable swap on /dev/xvdc1 early.
[2026-03-31 15:18:19] [.[0;32m OK .[0m] Finished .[0;1;39mdev-xvdc1-swap.service.[0m - Enable swap on /dev/xvdc1 early.
[2026-03-31 15:18:19] [ 4.598706] systemd[1]: Finished kmod-static-nodes.service - Create List of Static Device Nodes.
[2026-03-31 15:18:19] [.[0;32m OK .[0m] Finished .[0;1;39mkmod-static-nodes.service.[0m…Create List of Static Device Nodes.
[2026-03-31 15:18:19] [ 4.598872] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[2026-03-31 15:18:19] [ 4.598968] systemd[1]: Finished modprobe@fuse.service - Load Kernel Module fuse.
[2026-03-31 15:18:19] [.[0;32m OK .[0m] Finished .[0;1;39mmodprobe@fuse.service.[0m - Load Kernel Module fuse.
[2026-03-31 15:18:19] [ 4.599110] systemd[1]: modprobe@loop.service: Deactivated successfully.
[2026-03-31 15:18:19] [ 4.599196] systemd[1]: Finished modprobe@loop.service - Load Kernel Module loop.
[2026-03-31 15:18:19] [.[0;32m OK .[0m] Finished .[0;1;39mmodprobe@loop.service.[0m - Load Kernel Module loop.
[2026-03-31 15:18:19] [ 4.599944] systemd[1]: Mounting sys-fs-fuse-connections.mount - FUSE Control File System...
[2026-03-31 15:18:19] Mounting .[0;1;39msys-fs-fuse-connections.mount.[0m - FUSE Control File System...
[2026-03-31 15:18:19] [ 4.602002] systemd[1]: systemd-repart.service - Repartition Root Disk skipped, no trigger condition checks were met.
[2026-03-31 15:18:19] [ 4.605506] systemd[1]: Starting [2026-03-31 15:18:19] systemd-tmpfiles-setup-dev-early.service - Create Static Device Nodes in /dev gracefully...
[2026-03-31 15:18:19] [ 4.763149] EXT4-fs (xvda3): re-mounted 951b6318-f030-4691-9e66-b3a463c9c6b2 r/w.
[2026-03-31 15:18:19] Starting .[0;1;39msystemd-tmpfiles-setup-de….[0m Device Nodes in /dev gracefully...
[2026-03-31 15:18:19] [ 4.777607] systemd-journald[446]: Collecting audit messages is enabled.
[2026-03-31 15:18:19] [ 4.778821] systemd[1]: Finished systemd-network-generator.service - Generate Network Units from Kernel Command Line.
[2026-03-31 15:18:19] [.[0;32m OK .[0m] Finished .[0;1;39msystemd-network-generator….[0mork Units from Kernel Command Line.
[2026-03-31 15:18:19] [ 4.779302] systemd[1]: Finished systemd-remount-fs.service - Remount Root and Kernel File Systems.
[2026-03-31 15:18:19] [.[0;32m OK .[0m] Finished .[0;1;39msystemd-remount-fs.servic….[0mmount Root and Kernel File Systems.
[2026-03-31 15:18:19] [ 4.780039] systemd[1]: Mounted sys-fs-fuse-connections.mount - FUSE Control File System.
[2026-03-31 15:18:19] [.[0;32m OK .[0m] Mounted .[0;1;39msys-fs-fuse-connections.mount.[0m - FUSE Control File System.
[2026-03-31 15:18:19] [ 4.780345] audit: type=1130 audit(1774959499.584:4): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=systemd-network-generator comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[2026-03-31 15:18:19] [ 4.780408] audit: type=1130 audit(1774959499.584:5): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=systemd-remount-fs comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[2026-03-31 15:18:19] [ 4.782120] systemd[1]: systemd-hwdb-update.service - Rebuild Hardware Database skipped, unmet condition check ConditionNeedsUpdate=/etc
[2026-03-31 15:18:19] [ 4.782218] systemd[1]: systemd-tpm2-setup.service - TPM SRK Setup skipped, unmet condition check ConditionSecurity=measured-uki
[2026-03-31 15:18:19] [ 4.782817] systemd[1]: Finished systemd-udev-load-credentials.service - Load udev Rules from Credentials.
[2026-03-31 15:18:19] [.[0;32m OK .[0m] Finished .[0;1;39msystemd-udev-load-credent….[0m- Load udev Rules from Credentials.
[2026-03-31 15:18:19] [ 4.783264] audit: type=1130 audit(1774959499.588:6): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=systemd-udev-load-credentials comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[2026-03-31 15:18:19] [ 4.784738] systemd[1]: Finished systemd-modules-load.service - Load Kernel Modules.
[2026-03-31 15:18:19] [.[0;32m OK .[0m] Finished .[0;1;39msystemd-modules-load.service.[0m - Load Kernel Modules.
[2026-03-31 15:18:19] [ 4.787714] audit: type=1130 audit(1774959499.591:7): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=systemd-modules-load comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[2026-03-31 15:18:19] [ 4.791920] systemd[1]: Starting qubes-db.service - Qubes DB agent...
[2026-03-31 15:18:19] Starting .[0;1;39mqubes-db.service.[0m - Qubes DB agent...
[2026-03-31 15:18:19] [ 4.795378] systemd[1]: Starting systemd-sysctl.service - Apply Kernel Variables...
[2026-03-31 15:18:19] Starting .[0;1;39msystemd-sysctl.service.[0m - Apply Kernel Variables...
[2026-03-31 15:18:19] [ 4.795608] systemd[1]: Started systemd-journald.service - Journal Service.
[2026-03-31 15:18:19] [.[0;32m OK .[0m] Started .[0;1;39msystemd-journald.service.[0m - Journal Service.
[2026-03-31 15:18:19] [ 4.795953] audit: type=1130 audit(1774959499.601:8): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[2026-03-31 15:18:19] Starting .[0;1;39msystemd-journal-flush.ser….[0msh Journal to Persistent Storage...
[2026-03-31 15:18:19] [ 4.822264] systemd-journald[446]: Received client request to flush runtime journal.
[2026-03-31 15:18:19] [.[0;32m OK .[0m] Started .[0;1;39mqubes-db.service.[0m - Qubes DB agent.
[2026-03-31 15:18:19] [ 4.840320] audit: type=1130 audit(1774959499.645:9): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 [2026-03-31 15:18:19] msg='unit=qubes-db comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[2026-03-31 15:18:19] Starting .[0;1;39mqubes-sysinit.service.[0m - Init Qubes Services settings...
[2026-03-31 15:18:19] Starting .[0;1;39msystemd-random-seed.service.[0m - Load/Save OS Random Seed...
[2026-03-31 15:18:19] [.[0;32m OK .[0m] Finished .[0;1;39msystemd-udev-trigger.service.[0m - Coldplug All udev Devices.
[2026-03-31 15:18:19] [ 4.961229] audit: type=1130 audit(1774959499.766:10): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=systemd-udev-trigger comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[2026-03-31 15:18:19] [.[0;32m OK .[0m] Finished .[0;1;39msystemd-sysctl.service.[0m - Apply Kernel Variables.
[2026-03-31 15:18:19] [.[0;1;31mFAILED.[0m] Failed to start .[0;1;39msystemd-random-see…service.[0m - Load/Save OS Random Seed.
[2026-03-31 15:18:19] See 'systemctl status systemd-random-seed.service' for details.
[2026-03-31 15:18:19] [.[0;1;38:5:185mDEPEND.[0m] Dependency failed for .[0;1;39msysinit.target.[0m - System Initialization.
[2026-03-31 15:18:19] [.[0;1;38:5:185mDEPEND.[0m] Dependency failed for .[0;1;39mNetworkManager.service.[0m - Network Manager.
[2026-03-31 15:18:19] [.[0;1;38:5:185mDEPEND.[0m] Dependency failed for .[0;1;39msystemd-logi….[0mer Login Management Varlink Socket.
[2026-03-31 15:18:19] [.[0;1;38:5:185mDEPEND.[0m] Dependency failed for .[0;1;39mqubes-update…r.[0m - Periodically check for updates.
[2026-03-31 15:18:19] [.[0;1;38:5:185mDEPEND.[0m] Dependency failed for .[0;1;39msystemd-logind.service.[0m - User Login Management.
[2026-03-31 15:18:19] [.[0;1;38:5:185mDEPEND.[0m] Dependency failed for .[0;1;39mqubes-networ…e.[0m - Qubes network forwarding setup.
[2026-03-31 15:18:19] [.[0;1;38:5:185mDEPEND.[0m] Dependency failed for .[0;1;39mraid-check.t…r.[0m - Weekly RAID setup health check.
[2026-03-31 15:18:19] [.[0;1;38:5:185mDEPEND.[0m] Dependency failed for .[0;1;39mpolkit.service.[0m - Authorization Manager.
[2026-03-31 15:18:19] [.[0;1;38:5:185mDEPEND.[0m] Dependency failed for .[0;1;39mModemManager.service.[0m - Modem Manager.
[2026-03-31 15:18:19] [.[0;1;38:5:185mDEPEND.[0m] Dependency failed for .[0;1;39mfstrim.timer.[0m…used filesystem blocks once a week.
[2026-03-31 15:18:20] [.[0;1;38:5:185mDEPEND.[0m] Dependency failed for .[0;1;39mqubes-update….[0mon to updates proxy over Qubes RPC.
[2026-03-31 15:18:20] [.[0;1;38:5:185mDEPEND.[0m] Dependency failed for .[0;1;39mserial-getty…vc0.service.[0m - Serial Getty on hvc0.
[2026-03-31 15:18:20] [.[0;1;38:5:185mDEPEND.[0m] Dependency failed for .[0;1;39mlogrotate.timer.[0m - Daily rotation of log files.
[2026-03-31 15:18:20] [.[0;1;38:5:185mDEPEND.[0m] Dependency failed for .[0;1;39mgetty@tty1.service.[0m - Getty on tty1.
[2026-03-31 15:18:20] [.[0;1;38:5:185mDEPEND.[0m] Dependency failed for .[0;1;39mabrt-oops.service.[0m - ABRT kernel log watcher.
[2026-03-31 15:18:20] [.[0;1;38:5:185mDEPEND.[0m] Dependency failed for .[0;1;39mqubes-firewall.service.[0m - Qubes firewall updater.
[2026-03-31 15:18:20] [.[0;1;38:5:185mDEPEND.[0m] Dependency failed for .[0;1;39mabrtd.service.[0m - ABRT Daemon.
[2026-03-31 15:18:20] [.[0;1;38:5:185mDEPEND.[0m] Dependency failed for .[0;1;39mabrt-vmcore.…vice.[0m - ABRT kernel panic detection.
[2026-03-31 15:18:20] [.[0;1;38:5:185mDEPEND.[0m] Dependency failed for .[0;1;39mabrt-xorg.service.[0m - ABRT Xorg log watcher.
[2026-03-31 15:18:20] [.[0;1;38:5:185mDEPEND.[0m] Dependency failed for .[0;1;39mabrt-journal….[0m- ABRT coredumpctl message creator.
[2026-03-31 15:18:20] [.[0;1;38:5:185mDEPEND.[0m] Dependency failed for .[0;1;39mauthselect-a…service.[0m - Apply authselect changes.
[2026-03-31 15:18:20] [.[0;1;38:5:185mDEPEND.[0m] Dependency failed for .[0;1;39mqubes-gui-agent.service.[0m - Qubes GUI Agent.
[2026-03-31 15:18:20] [.[0;1;38:5:185mDEPEND.[0m] Dependency failed for .[0;1;39mdbus.socket.[0m - D-Bus System Message Bus Socket.
[2026-03-31 15:18:20] [.[0;1;38:5:185mDEPEND.[0m] Dependency failed for .[0;1;39mdbus-broker.service.[0m - D-Bus System Message Bus.
[2026-03-31 15:18:20] [.[0;1;38:5:185mDEPEND.[0m] Dependency failed for .[0;1;39msystemd-tmpf….[0my Cleanup of Temporary Directories.
[2026-03-31 15:18:20] [.[0;1;38:5:185mDEPEND.[0m] Dependency failed for .[0;1;39mbasic.target.[0m - Basic System.
[2026-03-31 15:18:20] [.[0;1;38:5:185mDEPEND.[0m] Dependency failed for .[0;1;39mmulti-user.target.[0m - Multi-User System.
[2026-03-31 15:18:20] [.[0;1;38:5:185mDEPEND.[0m] Dependency failed for .[0;1;39msystemd-pcrp…e.service.[0m - TPM PCR Barrier (User).
[2026-03-31 15:18:20] [.[0;1;38:5:185mDEPEND.[0m] Dependency failed for .[0;1;39mqubes-antisp….[0mQubes anti-spoofing firewall rules.
[2026-03-31 15:18:20] [.[0;1;38:5:185mDEPEND.[0m] Dependency failed for .[0;1;39mqubes-iptabl…ice.[0m - Qubes base firewall settings.
[2026-03-31 15:18:20] [.[0;1;38:5:185mDEPEND.[0m] Dependency failed for .[0;1;39mnetwork-pre.target.[0m - Preparation for Network.
[2026-03-31 15:18:20] [.[0;1;38:5:185mDEPEND.[0m] Dependency failed for .[0;1;39mqubes-misc-p…ice.[0m - Qubes misc post-boot actions.
[2026-03-31 15:18:20] [.[0;1;38:5:185mDEPEND.[0m] Dependency failed for .[0;1;39mqubes-qrexec….service.[0m - Qubes remote exec agent.
[2026-03-31 15:18:20] [.[0;1;38:5:185mDEPEND.[0m] Dependency failed for .[0;1;39mqubes-update….[0m - Qubes updates proxy (tinyproxy).
[2026-03-31 15:18:20] [.[0;1;38:5:185mDEPEND.[0m] Dependency failed for .[0;1;39mqubes-networ…ervice.[0m - Qubes network uplink wait.
[2026-03-31 15:18:20] [.[0;1;38:5:185mDEPEND.[0m] Dependency failed for .[0;1;39msystemd-user…ons.service.[0m - Permit User Sessions.
[2026-03-31 15:18:20] [.[0;1;38:5:185mDEPEND.[0m] Dependency failed for .[0;1;39mxendriverdom….[0m - Xen driver domain device daemon.
[2026-03-31 15:18:20] [.[0;1;38:5:185mDEPEND.[0m] Dependency failed for .[0;1;39msystemd-host…d.socket.[0m - Hostname Service Socket.
[2026-03-31 15:18:20] [.[0;1;38:5:185mDEPEND.[0m] Dependency failed for .[0;1;39mqubes-sync-t…timer.[0m - Update system time each 6h.
[2026-03-31 15:18:20] [.[0;1;38:5:185mDEPEND.[0m] Dependency failed for .[0;1;39mqubes-meminf….[0m Qubes memory information reporter.
[2026-03-31 15:18:20] [.[0;1;38:5:185mDEPEND.[0m] Dependency failed for .[0;1;39munbound-anch….[0mf the root trust anchor for DNSSEC.
[2026-03-31 15:18:20] [.[0;1;38:5:185mDEPEND.[0m] Dependency failed for .[0;1;39mdracut-shutd….[0mRestore /run/initramfs on shutdown.
[2026-03-31 15:18:20] [ 5.158158] kauditd_printk_skb: 2 callbacks suppressed
[2026-03-31 15:18:20] [ 5.158162] audit: type=1130 audit(1774959499.963:13): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=systemd-random-seed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[2026-03-31 15:18:20] [.[0;32m OK .[0m] Finished .[0;1;39msystemd-tmpfiles-setup-de….[0mic Device Nodes in /dev gracefully.
[2026-03-31 15:18:20] [ 5.164211] audit: type=1130 audit(1774959499.969:14): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=systemd-tmpfiles-setup-dev-early comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[2026-03-31 15:18:20] [.[0;32m OK .[0m] Reached target .[0;1;39mgetty.target.[0m - Login Prompts.
[2026-03-31 15:18:20] [.[0;32m OK .[0m] Reached target .[0;1;39mtimers.target.[0m - Timer Units.
[2026-03-31 15:18:20] Starting .[0;1;39mdracut-shutdown-onfailure….[0mtdown failure to perform cleanup...
[2026-03-31 15:18:20] Starting .[0;1;39msystemd-tmpfiles-setup-de….[0meate Static Device Nodes in /dev...
[2026-03-31 15:18:20] [.[0;1;31mFAILED.[0m] Failed to start .[0;1;39mqubes-sysinit.service.[0m - Init Qubes Services settings.
[2026-03-31 15:18:20] See 'systemctl status qubes-sysinit.service' for details.
[2026-03-31 15:18:20] [.[0;1;38:5:185mDEPEND.[0m] Dependency failed for .[0;1;39mqubes-relabe…rw.service.[0m - Relabel /rw and /home.
[2026-03-31 15:18:20] [.[0;1;38:5:185mDEPEND.[0m] Dependency failed for .[0;1;39mqubes-relabel-root.service.[0m - Relabel /.
[2026-03-31 15:18:20] [ 5.178876] audit: type=1130 audit(1774959499.984:15): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=qubes-sysinit comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[2026-03-31 15:18:20] [.[0;32m OK .[0m] Finished .[0;1;39mdracut-shutdown-onfailure….[0mhutdown failure to perform cleanup.
[2026-03-31 15:18:20] [ 5.183101] audit: type=1130 audit(1774959499.988:16): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=dracut-shutdown-onfailure comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[2026-03-31 15:18:20] [ 5.183183] audit: type=1131 audit(1774959499.988:17): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=dracut-shutdown-onfailure comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[2026-03-31 15:18:20] Starting .[0;1;39mqubes-rootfs-resize.service.[0m - Adjust root filesystem size...
[2026-03-31 15:18:20] [.[0;32m OK .[0m] Finished .[0;1;39msystemd-tmpfiles-setup-de….[0mCreate Static Device Nodes in /dev.
[2026-03-31 15:18:20] [ 5.217709] audit: type=1130 audit(1774959500.022:18): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=systemd-tmpfiles-setup-dev comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[2026-03-31 15:18:20] [.[0;32m OK .[0m] Reached target .[0;1;39mlocal-fs-pre.target.[0m…Preparation for Local File Systems.
[2026-03-31 15:18:20] [.[0;32m OK .[0m] Set up automount .[0;1;39mefi.automount.[0m - EFI System Partition Automount.
[2026-03-31 15:18:20] [ 5.218842] audit: type=1334 audit(1774959500.024:19): prog-id=24 op=UNLOAD
[2026-03-31 15:18:20] [ 5.218893] audit: type=1334 audit(1774959500.024:20): prog-id=23 op=UNLOAD
[2026-03-31 15:18:20] [ 5.358023] audit: type=1334 audit(1774959500.162:21): prog-id=50 op=LOAD
[2026-03-31 15:18:20] [ 5.358054] audit: type=1334 audit(1774959500.162:22): prog-id=51 op=LOAD
[2026-03-31 15:18:20] Starting .[0;1;39msystemd-udevd.service.[0m - R…ager for Device Events and Files...
[2026-03-31 15:18:20] [.[0;32m OK .[0m] Finished .[0;1;39msystemd-journal-flush.ser….[0mlush Journal to Persistent Storage.
[2026-03-31 15:18:20] [.[0;32m OK .[0m] Finished .[0;1;39mqubes-rootfs-resize.service.[0m - Adjust root filesystem size.
[2026-03-31 15:18:20] [.[0;32m OK .[0m] Started .[0;1;39msystemd-udevd.service.[0m - Ru…anager for Device Events and Files.
Starting .[0;1;39msystemd-fsck@dev-xvdb.ser….[0m- File System Check on /dev/xvdb...
[2026-03-31 15:18:20] [.[0;32m OK .[0m] Finished .[0;1;39msystemd-fsck@dev-xvdb.ser…e.[0m - File System Check on /dev/xvdb.
[2026-03-31 15:18:20] Starting .[0;1;39mqubes-mount-dirs.service.[0m …itialize and mount /rw and /home...
[2026-03-31 15:18:20] [ 5.729302] xen_netfront: Initialising Xen virtual ethernet driver
[2026-03-31 15:18:20] [ 5.737653] xen_netfront: backend supports XDP headroom
[2026-03-31 15:18:20] [ 5.737671] vif vif-0: bouncing transmitted data to zeroed pages
[2026-03-31 15:18:20] [ 5.739160] EXT4-fs (xvdb): mounted filesystem a7d954e5-b365-46c8-8c6b-ee7f0675435d r/w with ordered data mode. Quota mode: none.
[2026-03-31 15:18:20] Starting .[0;1;39msystemd-vconsole-setup.service.[0m - Virtual Console Setup...
[2026-03-31 15:18:20] [ 5.746102] EXT4-fs (xvdb): resizing filesystem from 524288 to 3932160 blocks
[2026-03-31 15:18:20] [ 5.799078] EXT4-fs (xvdb): resized filesystem to 3932160
[.[0;32m OK .[0m] Finished .[0;1;39msystemd-vconsole-setup.service.[0m - Virtual Console Setup.
[2026-03-31 15:18:20] Starting .[0;1;39mdev-xvdc1-swap.service.[0m - Enable swap on /dev/xvdc1 early...
[2026-03-31 15:18:20] Starting .[0;1;39mqubes-db.service.[0m - Qubes DB agent...
[2026-03-31 15:18:20] [.[0;32m OK .[0m] Created slice .[0;1;39msystem-qubes\x2dnetw….[0mSlice /system/qubes-network-uplink.
[2026-03-31 15:18:20] [.[0;32m OK .[0m] Finished .[0;1;39mdev-xvdc1-swap.service.[0m - Enable swap on /dev/xvdc1 early.
[2026-03-31 15:18:20] [ 5.894653] intel_rapl_msr: PL4 support detected.
[2026-03-31 15:18:21] [.[0;32m OK .[0m] Finished .[0;1;39mqubes-mount-dirs.service.[0m …Initialize and mount /rw and /home.
[2026-03-31 15:18:21] Mounting .[0;1;39mhome.mount.[0m - /home...
[2026-03-31 15:18:21] Mounting .[0;1;39musr-local.mount.[0m - /usr/local...
[2026-03-31 15:18:21] [.[0;32m OK .[0m] Mounted .[0;1;39mhome.mount.[0m - /home.
[2026-03-31 15:18:21] [.[0;32m OK .[0m] Mounted .[0;1;39musr-local.mount.[0m - /usr/local.
[2026-03-31 15:18:21] [.[0;32m OK .[0m] Reached target .[0;1;39mlocal-fs.target.[0m - Local File Systems.
[2026-03-31 15:18:21] [.[0;32m OK .[0m] Listening on .[0;1;39msystemd-bootctl.socket.[0m - Boot Entries Service Socket.
[2026-03-31 15:18:21] [.[0;32m OK .[0m] Listening on .[0;1;39msystemd-sysext.socket.[0m… System Extension Image Management.
[2026-03-31 15:18:21] [.[0;32m OK .[0m] Reached target .[0;1;39msockets.target.[0m - Socket Units.
[2026-03-31 15:18:21] Starting .[0;1;39mqubes-bind-dirs.service.[0m -…gured bind files and directories...
[2026-03-31 15:18:23] [.[0m.[0;31m* .[0m] (1 of 2) Job qubes-bind-dirs.service/start running (4s / no limit)
[2026-03-31 15:18:24] .M
.[K[.[0;1;31m*.[0m.[0;31m* .[0m] (1 of 2) Job qubes-bind-dirs.service/start running (4s / no limit)
.[K[.[0;31m*.[0;1;31m*.[0m.[0;31m* .[0m] (1 of 2) Job qubes-bind-dirs.service/start running (5s / no limit)
[2026-03-31 15:18:25] .M
.[K[ .[0;31m*.[0;1;31m*.[0m.[0;31m* .[0m] (2 of 2) Job qubes-db.service/start running (4s / 45s)
.[K[ .[0;31m*.[0;1;31m*.[0m.[0;31m* .[0m] (2 of 2) Job qubes-db.service/start running (5s / 45s)
[2026-03-31 15:18:26] .M
.[K[ .[0;31m*.[0;1;31m*.[0m.[0;31m*.[0m] (2 of 2) Job qubes-db.service/start running (5s / 45s)
[2026-03-31 15:18:27] .M
.[K[ .[0;31m*.[0;1;31m*.[0m] (1 of 2) Job qubes-bind-dirs.service/start running (7s / no limit)
.[K[ .[0;31m*.[0m] (1 of 2) Job qubes-bind-dirs.service/start running (8s / no limit)
[2026-03-31 15:18:28] .M
.[K[ .[0;31m*.[0;1;31m*.[0m] (1 of 2) Job qubes-bind-dirs.service/start running (9s / no limit)
[2026-03-31 15:18:28] ^[[24;1R^[[24;80R^[[24;1R^[[24;80R.M
.[K[ .[0;31m*.[0;1;31m*.[0m.[0;31m*.[0m] (2 of 2) Job qubes-db.service/start running (8s / 45s)
[2026-03-31 15:18:29] .M
.[K[ .[0;31m*.[0;1;31m*.[0m.[0;31m* .[0m] (2 of 2) Job qubes-db.service/start running (8s / 45s)
[2026-03-31 15:18:30] .M
.[K[ .[0;31m*.[0;1;31m*.[0m.[0;31m* .[0m] (2 of 2) Job qubes-db.service/start running (9s / 45s)
.[K[.[0;31m*.[0;1;31m*.[0m.[0;31m* .[0m] (1 of 2) Job qubes-bind-dirs.service/start running (11s / no limit)
[2026-03-31 15:18:31] .M
.[K[.[0;1;31m*.[0m.[0;31m* .[0m] (1 of 2) Job qubes-bind-dirs.service/start running (11s / no limit)
.[K[.[0m.[0;31m* .[0m] (1 of 2) Job qubes-bind-dirs.service/start running (12s / no limit)
[2026-03-31 15:18:32] .M
.[K[.[0;1;31m*.[0m.[0;31m* .[0m] (2 of 2) Job qubes-db.service/start running (11s / 45s)
.[K[.[0;31m*.[0;1;31m*.[0m.[0;31m* .[0m] (2 of 2) Job qubes-db.service/start running (12s / 45s)
[2026-03-31 15:18:33] .M
.[K[ .[0;31m*.[0;1;31m*.[0m.[0;31m* .[0m] (2 of 2) Job qubes-db.service/start running (12s / 45s)
[2026-03-31 15:18:34] .M
.[K[ .[0;31m*.[0;1;31m*.[0m.[0;31m* .[0m] (1 of 2) Job qubes-bind-dirs.service/start running (14s / no limit)
.[K[ .[0;31m*.[0;1;31m*.[0m.[0;31m*.[0m] (1 of 2) Job qubes-bind-dirs.service/start running (15s / no limit)
[2026-03-31 15:18:35] .M
.[K[ .[0;31m*.[0;1;31m*.[0m] (1 of 2) Job qubes-bind-dirs.service/start running (16s / no limit)
.[K[ .[0;31m*.[0m] (2 of 2) Job qubes-db.service/start running (15s / 45s)
[2026-03-31 15:18:36] .M
.[K[ .[0;31m*.[0;1;31m*.[0m] (2 of 2) Job qubes-db.service/start running (15s / 45s)
[2026-03-31 15:18:37] .M
.[K[ .[0;31m*.[0;1;31m*.[0m.[0;31m*.[0m] (2 of 2) Job qubes-db.service/start running (16s / 45s)
.[K[ .[0;31m*.[0;1;31m*.[0m.[0;31m* .[0m] (1 of 2) Job qubes-bind-dirs.service/start running (18s / no limit)
[2026-03-31 15:18:38] .M
.[K[.[0;31m*.[0;1;31m*.[0m.[0;31m* .[0m] (1 of 2) Job qubes-bind-dirs.service/start running (19s / no limit)
[2026-03-31 15:18:39] .M
.[K[.[0;1;31m*.[0m.[0;31m* .[0m] (2 of 2) Job qubes-db.service/start running (18s / 45s)
.[K[.[0m.[0;31m* .[0m] (2 of 2) Job qubes-db.service/start running (19s / 45s)
[2026-03-31 15:18:40] .M
.[K[.[0;1;31m*.[0m.[0;31m* .[0m] (2 of 2) Job qubes-db.service/start running (19s / 45s)
[2026-03-31 15:18:41] .M
.[K[.[0;31m*.[0;1;31m*.[0m.[0;31m* .[0m] (1 of 2) Job qubes-bind-dirs.service/start running (21s / no limit)
.[K[ .[0;31m*.[0;1;31m*.[0m.[0;31m* .[0m] (1 of 2) Job qubes-bind-dirs.service/start running (22s / no limit)
[2026-03-31 15:18:42] .M
.[K[ .[0;31m*.[0;1;31m*.[0m.[0;31m* .[0m] (1 of 2) Job qubes-bind-dirs.service/start running (23s / no limit)
.[K[ .[0;31m*.[0;1;31m*.[0m.[0;31m*.[0m] (2 of 2) Job qubes-db.service/start running (22s / 45s)
[2026-03-31 15:18:43] .M
.[K[ .[0;31m*.[0;1;31m*.[0m] (2 of 2) Job qubes-db.service/start running (22s / 45s)
[2026-03-31 15:18:44] .M
.[K[ .[0;31m*.[0m] (2 of 2) Job qubes-db.service/start running (23s / 45s)
.[K[ .[0;31m*.[0;1;31m*.[0m] (1 of 2) Job qubes-bind-dirs.service/start running (25s / no limit)
[2026-03-31 15:18:45] .M
.[K[ .[0;31m*.[0;1;31m*.[0m.[0;31m*.[0m] (1 of 2) Job qubes-bind-dirs.service/start running (25s / no limit)
.[K[ .[0;31m*.[0;1;31m*.[0m.[0;31m* .[0m] (1 of 2) Job qubes-bind-dirs.service/start running (26s / no limit)
[2026-03-31 15:18:46] .M
.[K[ .[0;31m*.[0;1;31m*.[0m.[0;31m* .[0m] (2 of 2) Job qubes-db.service/start running (25s / 45s)
.[K[.[0;31m*.[0;1;31m*.[0m.[0;31m* .[0m] (2 of 2) Job qubes-db.service/start running (25s / 45s)
[2026-03-31 15:18:47] .M
.[K[.[0;1;31m*.[0m.[0;31m* .[0m] (2 of 2) Job qubes-db.service/start running (26s / 45s)
.[K[.[0m.[0;31m* .[0m] (1 of 2) Job qubes-bind-dirs.service/start running (28s / no limit)
[2026-03-31 15:18:48] .M
.[K[.[0;1;31m*.[0m.[0;31m* .[0m] (1 of 2) Job qubes-bind-dirs.service/start running (28s / no limit)
.[K[.[0;31m*.[0;1;31m*.[0m.[0;31m* .[0m] (1 of 2) Job qubes-bind-dirs.service/start running (29s / no limit)
[2026-03-31 15:18:49] .M
.[K[ .[0;31m*.[0;1;31m*.[0m.[0;31m* .[0m] (2 of 2) Job qubes-db.service/start running (28s / 45s)
[2026-03-31 15:18:50] .M
.[K[ .[0;31m*.[0;1;31m*.[0m.[0;31m*.[0m] (2 of 2) Job qubes-db.service/start running (29s / 45s)
.[K[ .[0;31m*.[0;1;31m*.[0m] (1 of 2) Job qubes-bind-dirs.service/start running (31s / no limit)
[2026-03-31 15:18:51] .M
.[K[ .[0;31m*.[0m] (1 of 2) Job qubes-bind-dirs.service/start running (31s / no limit)
.[K[ .[0;31m*.[0;1;31m*.[0m] (1 of 2) Job qubes-bind-dirs.service/start running (32s / no limit)
[2026-03-31 15:18:52] .M
.[K[ .[0;31m*.[0;1;31m*.[0m.[0;31m*.[0m] (2 of 2) Job qubes-db.service/start running (31s / 45s)
.[K[ .[0;31m*.[0;1;31m*.[0m.[0;31m* .[0m] (2 of 2) Job qubes-db.service/start running (31s / 45s)
[2026-03-31 15:18:53] .M
.[K[ .[0;31m*.[0;1;31m*.[0m.[0;31m* .[0m] (2 of 2) Job qubes-db.service/start running (32s / 45s)
.[K[.[0;31m*.[0;1;31m*.[0m.[0;31m* .[0m] (1 of 2) Job qubes-bind-dirs.service/start running (34s / no limit)
[2026-03-31 15:18:54] .M
.[K[.[0;1;31m*.[0m.[0;31m* .[0m] (1 of 2) Job qubes-bind-dirs.service/start running (34s / no limit)
.[K[.[0m.[0;31m* .[0m] (1 of 2) Job qubes-bind-dirs.service/start running (35s / no limit)
[2026-03-31 15:18:55] .M
.[K[.[0;1;31m*.[0m.[0;31m* .[0m] (2 of 2) Job qubes-db.service/start running (34s / 45s)
.[K[.[0;31m*.[0;1;31m*.[0m.[0;31m* .[0m] (2 of 2) Job qubes-db.service/start running (34s / 45s)
[2026-03-31 15:18:56] .M
.[K[ .[0;31m*.[0;1;31m*.[0m.[0;31m* .[0m] (2 of 2) Job qubes-db.service/start running (35s / 45s)
.[K[ .[0;31m*.[0;1;31m*.[0m.[0;31m* .[0m] (1 of 2) Job qubes-bind-dirs.service/start running (37s / no limit)
[2026-03-31 15:18:57] .M
.[K[ .[0;31m*.[0;1;31m*.[0m.[0;31m*.[0m] (1 of 2) Job qubes-bind-dirs.service/start running (37s / no limit)
.[K[ .[0;31m*.[0;1;31m*.[0m] (1 of 2) Job qubes-bind-dirs.service/start running (38s / no limit)
[2026-03-31 15:18:58] .M
.[K[ .[0;31m*.[0m] (2 of 2) Job qubes-db.service/start running (37s / 45s)
.[K[ .[0;31m*.[0;1;31m*.[0m] (2 of 2) Job qubes-db.service/start running (37s / 45s)
[2026-03-31 15:18:59] .M
.[K[ .[0;31m*.[0;1;31m*.[0m.[0;31m*.[0m] (2 of 2) Job qubes-db.service/start running (38s / 45s)
.[K[ .[0;31m*.[0;1;31m*.[0m.[0;31m* .[0m] (1 of 2) Job qubes-bind-dirs.service/start running (40s / no limit)
[2026-03-31 15:19:00] .M
.[K[.[0;31m*.[0;1;31m*.[0m.[0;31m* .[0m] (1 of 2) Job qubes-bind-dirs.service/start running (41s / no limit)
[2026-03-31 15:19:01] .M
.[K[.[0;1;31m*.[0m.[0;31m* .[0m] (2 of 2) Job qubes-db.service/start running (40s / 45s)
.[K[.[0m.[0;31m* .[0m] (2 of 2) Job qubes-db.service/start running (40s / 45s)
[2026-03-31 15:19:02] .M
.[K[.[0;1;31m*.[0m.[0;31m* .[0m] (2 of 2) Job qubes-db.service/start running (41s / 45s)
.[K[.[0;31m*.[0;1;31m*.[0m.[0;31m* .[0m] (1 of 2) Job qubes-bind-dirs.service/start running (43s / no limit)
[2026-03-31 15:19:03] .M
.[K[ .[0;31m*.[0;1;31m*.[0m.[0;31m* .[0m] (1 of 2) Job qubes-bind-dirs.service/start running (43s / no limit)
.[K[ .[0;31m*.[0;1;31m*.[0m.[0;31m* .[0m] (1 of 2) Job qubes-bind-dirs.service/start running (44s / no limit)
[2026-03-31 15:19:04] .M
.[K[ .[0;31m*.[0;1;31m*.[0m.[0;31m*.[0m] (2 of 2) Job qubes-db.service/start running (43s / 45s)
.[K[ .[0;31m*.[0;1;31m*.[0m] (2 of 2) Job qubes-db.service/start running (43s / 45s)
[2026-03-31 15:19:05] .M
.[K[ .[0;31m*.[0m] (2 of 2) Job qubes-db.service/start running (44s / 45s)
.[K[ .[0;31m*.[0;1;31m*.[0m] (1 of 2) Job qubes-bind-dirs.service/start running (46s / no limit)
[2026-03-31 15:19:06] .M
.[K[ .[0;31m*.[0;1;31m*.[0m.[0;31m*.[0m] (1 of 2) Job qubes-bind-dirs.service/start running (46s / no limit)
.[K[ .[0;31m*.[0;1;31m*.[0m.[0;31m* .[0m] (1 of 2) Job qubes-bind-dirs.service/start running (47s / no limit)
[2026-03-31 15:19:07] .M
.[K[ .[0;31m*.[0;1;31m*.[0m.[0;31m* .[0m] (2 of 2) Job qubes-db.service/start running (46s / 1min 30s)
.[K[.[0;31m*.[0;1;31m*.[0m.[0;31m* .[0m] (2 of 2) Job qubes-db.service/start running (46s / 1min 30s)
[2026-03-31 15:19:08] .M
.[K[.[0;1;31m*.[0m.[0;31m* .[0m] (2 of 2) Job qubes-db.service/start running (47s / 1min 30s)
.[K[.[0m.[0;31m* .[0m] (1 of 2) Job qubes-bind-dirs.service/start running (49s / no limit)
[2026-03-31 15:19:09] .M
.[K[.[0;1;31m*.[0m.[0;31m* .[0m] (1 of 2) Job qubes-bind-dirs.service/start running (49s / no limit)
.[K[.[0;31m*.[0;1;31m*.[0m.[0;31m* .[0m] (1 of 2) Job qubes-bind-dirs.service/start running (50s / no limit)
[2026-03-31 15:19:10] .M
.[K[ .[0;31m*.[0;1;31m*.[0m.[0;31m* .[0m] (2 of 2) Job qubes-db.service/start running (49s / 1min 30s)
[2026-03-31 15:19:11] .M
.[K[ .[0;31m*.[0;1;31m*.[0m.[0;31m*.[0m] (2 of 2) Job qubes-db.service/start running (50s / 1min 30s)
.[K[ .[0;31m*.[0;1;31m*.[0m] (1 of 2) Job qubes-bind-dirs.service/start running (52s / no limit)
[2026-03-31 15:19:12] .M
.[K[ .[0;31m*.[0m] (1 of 2) Job qubes-bind-dirs.service/start running (52s / no limit)
