Fedora 43 Workstation or Silverblue
Hello, I am a longtime QubesOS user for more than 6 years.
I got a new device and installed Fedora 43 Workstation on it, I noticed there is Fedora Silverblue.
Which would be best for me?
I’m into Security, Encryption, Anonymity, VPN’s.
I use VPN’s, and Tor a lot.
Which is better for exploit protection like QubesOS.
I use PGP, Crypto, Password Managers, and other things that need to be safe and secure.
Which is the best for my use type Workstation or Silverblue?
Unless I misunderstood, you should ask this in any forum about Fedora or security but this forum is only about Qubes OS
Workstation is live version. You can thinker with it. You have access to everything.
Silverblue is an atomic version. /root is blocked from you, you can’t thinker with it, no drivers installation, no network combinations, just install system and forget. You can only install app in a user space. It’s little bit hardened. Once in a while there is system update.
Closing because this is not specific to Qubes.
