Fedora 43 templates available for Qubes OS 4.3
The following new Fedora 43 templates are now available for Qubes OS 4.3:
  • fedora-43-xfce (default Fedora template with the Xfce desktop environment)
  • fedora-43 (alternative Fedora template with the GNOME desktop environment)
  • fedora-43-minimal (minimal template for advanced users)
Note: Fedora 43 template availability for Qubes OS 4.2 will be announced separately.
There are two ways to upgrade a template to a new Fedora release:
  1. Recommended: Install a fresh template to replace an existing one. This option is simpler for less experienced users, but it won’t preserve any modifications you’ve made to your template. After you install the new template, you’ll have to redo your desired template modifications (if any) and switch everything that was set to the old template to the new template. If you choose to modify your template, you may wish to write those modifications down so that you remember what to redo on each fresh install. To see a log of package manager actions, open a terminal in the template and use the dnf history command.
  2. Advanced: Perform an in-place upgrade of an existing Fedora template. This option will preserve any modifications you’ve made to the template, but it may be more complicated for less experienced users.
Note: No user action is required regarding the OS version in dom0 (see our note on dom0 and EOL).
This is a companion discussion topic for the original entry at https://www.qubes-os.org/news/2026/02/06/fedora-43-templates-available/
After the Fedora 43 template was released, I did an in-place upgrade on my fedora-42-xfce from an almost fresh Qubes OS 4.3 install. As a result, my existing fedora-42 template didn’t have gnome-terminal installed and was using xfce4-terminal instead.
If someone with a permissions could update the docs, I’d appreciate it.
Sincerely
Max
Consistency improvement would be to rename fedora-43 to fedora-43-gnome, and create fedora-43-kde (because creating kde template from minimal is a not easy).
A post was split to a new topic: Python3-gbulb Package Missing from Fedora 43 Minimal
I would also really appreciate this.
Now with whonix 18 there are 3 different DEs and none of them are KDE. I realize some consider it bloated but personally the difference is not enough to appreciate the inconsistency.
