Fedora 41 template
According to qubes-os.org/news/2024/12/07 New Fedora 41 templates are now available for Qubes OS 4.2 in standard, minimal, and Xfce varieties.
However in the GUI Qubes Template Manager I see the standard and Xfce templates only being available in the testing repository.
Am I missing anything?
fedora-41-minimal → qubes-templates-itl repository
fedora-41-xfce → qubes-templates-itl-testing
fedora-41 → qubes-templates-itl
EDIT: Looks like XFCE is still in testing phase, as in I am confirming what you are seeing. Need More Coffee…
The testing repo has a newer version of fedora-41-xfce than the stable repo. It’s clearer in the CLI:
[user@dom0 ~]$ qvm-template list --available --all-versions fedora-41-xfce
Available Templates
fedora-41-xfce  0:4.2.0-202412200202  qubes-templates-itl-testing
fedora-41-xfce  0:4.2.0-202411301214  qubes-templates-itl-testing
In the CLI I get this output:
[gz007@dom0 ~]$ qvm-template list --available all-versions fedora-41-xfce
Available Templates
[gz007@dom0 ~]$
That’s missing two dashes before all-versions
Yes, thank you, now it shows the stable xfce version as well in the CLI.
But now, how do I install the template since it doesn’t show up in the
GUI Qubes Template Manager?
Sudo qubes-dom0-update qubes-template-fedora-41-xfce
In dom0 terminal
@corny
In dom0 terminal
is giving this output:
[gz007@dom0 ~]$ sudo qubes-dom0-update qubes-template-fedora-41-xfce
Using sys-firewall as UpdateVM for Dom0
Downloading packages. This may take a while…
Redirecting to ‘qvm-template install fedora-41-xfce’
Downloading ‘qubes-template-fedora-41-xfce-0:4.2.0-202412200202’…
qubes-template-fedora-41-xfce-0:4.2.0-202412200202: 100%|▉| 1.88G/1.88G [00:53<0
Installing template ‘fedora-41-xfce’…
fedora-41-xfce: Importing data
[gz007@dom0 ~]$
The version nr. of the download is the same as the one in the testing repo, and not the stable one.
Thank you for for your time anyway.
If you want the stable one, you can append the version to the template like this:
qvm-template install fedora-41-xfce-4.2.0-202411301214
Or, you can temporarily disable the testing repo to download the stable one:
qvm-template install fedora-41-xfce --disablerepo=qubes-templates-itl-testing
@DVM
Thank you, that solved it. I did the same for the stable version of fedora-41.
However I still wonder why the stable versions don’t show up in The GUI Qubes Template Manager.
