when i connect an external monitor, fedora-41 based AppVMs do not recognize the new clickable area and thus have to be restarted to be working again. In debian-based AppVMs, this is working flawlessly.
This is not related to video ram adjustments as discussed at GUI configuration | Qubes OS
I’ve tried my best to debug the issue:
When I connect the new monitor, debian-based VMs have the following xrandr output and are working fine:
Screen 0: minimum 64 x 64, current 3440 x 2640, maximum 32767 x 32767
DUMMY0 connected 1920x1200+0+1440 325mm x 203mm
QB3440x2640 18.90 +
QB1920x1200 59.88*
DUMMY1 connected 3440x1440+0+0 0mm x 0mm
QB3440x2640 18.90 +
QB3440x1440 59.94*
In contrast, fedora-41 based AppVMs have the following xrandr output and the area within the “old” resolution of the original monitor (1920x1200) is clickable but the extended one (3440x1440) is not:
Screen 0: minimum 64 x 64, current 1920 x 1200, maximum 32767 x 32767
DUMMY0 connected primary 1920x1200+0+0 325mm x 203mm
QB1920x1200 41.50*+
DUMMY1 disconnected
QB3440x1440 59.94
Now, when I reboot the fedora-41 based AppVM, everything works fine and the xrandr output is correct and I can click everything. The same works if I do systemctl restart qubes-gui-agent in the fedora-41 AppVM and without a restart, all windows disappear but then the xrandr configuration is correct and I can restart apps in the still running AppVM and click everything.
Interestingly, when I run qvm-start-gui --notify-monitor-layout AppVM in dom0 I get the following errors in journalctl output of the AppVM:
Jan 04 18:53:49 AppVM qubes.SetMonitorLayout-dom0[3675]: X Error of failed request: BadMatch (invalid parameter attributes)
Jan 04 18:53:49 AppVM qubes.SetMonitorLayout-dom0[3675]: Major opcode of failed request: 140 (RANDR)
Jan 04 18:53:49 AppVM qubes.SetMonitorLayout-dom0[3675]: Minor opcode of failed request: 7 (RRSetScreenSize)
Jan 04 18:53:49 AppVM qubes.SetMonitorLayout-dom0[3675]: Serial number of failed request: 186
Jan 04 18:53:49 AppVM qubes.SetMonitorLayout-dom0[3675]: Current serial number in output stream: 187
Jan 04 18:53:49 AppVM systemd[728]: Started dbus-:1.2-org.xfce.Xfconf@3.service.
For me, this looks similar to the issue mentioned in monitor layout change regression in 4.0-rc2 · Issue #3253 · QubesOS/qubes-issues · GitHub but I’m not quite sure. Any hints or suggestions?
Thank you
David
