New Fedora 37 templates are now available! We provide fresh Fedora 37 template packages through the official Qubes repositories, which you can install in dom0 by following the standard installation instructions. Alternatively, we also provide step-by-step instructions for performing an in-place upgrade of an existing Fedora template. After upgrading your templates, please remember to switch all qubes that were using the old template to use the new one.
As a reminder, Fedora 35 has reached EOL. If you have not already done so, we strongly recommend that you upgrade all Fedora 35 templates and standalones to a supported template release immediately.
Please note that no user action is required regarding the OS version in dom0 (see our note on dom0 and EOL).
This is a companion discussion topic for the original entry at https://www.qubes-os.org/news/2023/03/03/fedora-37-templates-available/
