When I go through the Qubes Updater, this happens:
Updating fedora-34
Error on updating fedora-34: Command '['sudo', 'qubesctl', '--skip-dom0', '--targets=fedora-34', '--show-output', 'state.sls', 'update.qubes-vm']' returned non-zero exit status 20
fedora-34:
Function: pkg.installed
Result: True
Comment: All specified packages are already installed and are the desired version
Started: 21:28:39.563557
Duration: 1074.881 ms
Changes:
Function: file.absent
Result: True
Comment: File /usr/lib/rpm/macros.d/macros.qubes is not present
Started: 21:28:40.642151
Duration: 0.908 ms
Changes:
Function: cmd.script
Result: False
Comment: Could not create DNF metadata cache
Started: 21:28:40.644067
Duration: 2299.092 ms
Changes:
Function: cmd.run
Result: False
Comment: Command "/usr/lib/qubes/upgrades-status-notify" run
Started: 21:28:42.944768
Duration: 2748.059 ms
Changes:
pid: 1785
retcode: 1
stderr:
Error: Failed to download metadata for repo 'updates': Cannot prepare internal mirrorlist: Curl error (56) Failure when receiving data from the peer for https://mirrors.fedoraproject.org/metalink?repo=updates-released-f34&arch=q86_64 [Recv failure: Connection reset by peer]
stdout:
Summary for fedora-34
Succeeded: 2 (changed=1)
Failed: 3
Total states run: 5
Total run time: 6.123 s
And when I go to terminal, I get this.
[user@fedora-34 ~]$ sudo dnf upgrade
Fedora 34 - x86_64 - Updates 0.0 B/s | 0 B 00:01
Errors during downloading metadata for repository 'updates':
- Curl error (56): Failure when receiving data from the peer for https://mirrors.fedoraproject.org/metalink?repo=updates-released-f34&arch=x86_64 [Recv failure: Connection reset by peer]
Error: Failed to download metadata for repo 'updates': Cannot prepare internal mirrorlist: Curl error (56): Failure when receiving data from the peer for https://mirrors.fedoraproject.org/metalink?repo=updates-released-f34&arch=x86_64 [Recv failure: Connection reset by peer]
pls help
Thank you
