Fedora 33 - Broken dependencies for nss
Hello
got a stuck update-icon for fedora-33 so i checked manually:
$ sudo dnf update
Warning: Enforcing GPG signature check globally as per active RPM security policy (see 'gpgcheck' in dnf.conf(5) for how to squelch this message)
Last metadata expiration check: xxx ago on xxx.
Dependencies resolved.
 Problem 1: cannot install the best update candidate for package nss-3.62.0-1.fc33.x86_64
  - nothing provides nspr >= 4.30.0 needed by nss-3.63.0-1.fc33.x86_64
 Problem 2: cannot install the best update candidate for package nss-softokn-3.62.0-1.fc33.x86_64
  - nothing provides nspr >= 4.30.0 needed by nss-softokn-3.63.0-1.fc33.x86_64
 Problem 3: cannot install the best update candidate for package nss-util-3.62.0-1.fc33.x86_64
  - nothing provides nspr >= 4.30.0 needed by nss-util-3.63.0-1.fc33.x86_64
 Problem 4: package nss-sysinit-3.63.0-1.fc33.x86_64 requires nss(x86-64) = 3.63.0-1.fc33, but none of the providers can be installed
  - cannot install the best update candidate for package nss-sysinit-3.62.0-1.fc33.x86_64
 Package                                    Architecture                          Version                                       Repository                              Size
Skipping packages with broken dependencies:
 nss                                        x86_64                                3.63.0-1.fc33                                 updates                                689 k
 nss-softokn                                x86_64                                3.63.0-1.fc33                                 updates                                384 k
 nss-sysinit                                x86_64                                3.63.0-1.fc33                                 updates                                 20 k
 nss-util                                   x86_64                                3.63.0-1.fc33                                 updates                                 90 k
Transaction Summary
Skip  4 Packages
Nothing to do.
Complete!
Any advice?
Not a Qubes problem - the Fedora repositories dont yet have the version
you need. The package should work its way through idc.
Experiencing the same here. The only annoying part is that it always shows in the Qube Update widget.
