I successfully installed fedora-33, updated my qubes (including dom0), and removed the fedora-32 TemplateVM. However, in my qubes menu (not the Qubes Manager) I still see an entry called fedora-32-dvm-vm. The icon looks like a box, unlike the others that are locks. The only available program is a terminal, but nothing happens if I try to open it.
In dom0, if I run sudo dnf history userinstalled the only fedora template I see installed is 33. I’ve restarted my computer as well.
How do I remove this “zombie” vm entry from the list? (Again, not the Qubes Manager but the dropdown menu of VMs on the top left)
Thanks!
