This program uses ec_sys kernel module to function. Check using find /lib/modules/$(uname -r) -type f -name '*.ko*' | grep ec_sys. If it isn’t listed, you’ll have to rebuild the kernel yourself manually. Arch Linux and Ubuntu do ship the kernel with this module available.
sudo modprobe ec_sys
modprobe: FATAL: Module ec_sys not found in directory /lib/modules/6.1.62-1.qubes.fc37.x86_64
I didn’t need predator sense software in ubuntu distro so would qubes and dom0 need it? Also the original predator sense software is closed source so is this safe to use?
I guess you need to figure out how the fans are controlled in Fedora Live USB.
Maybe check sensors-detect there or check the logs there or search in /sys the entries related to fan and then search where are they coming from.
You can ask on general Linux forums/chats/etc how can you find out how your fans are controlled in your system (Fedora Live) which package/kernel modules are involved that could be missing in dom0 Fedora system.
They told me there was only power profiles daemon in Fedora Live and there wasn’t any packages or modules controlling fans. Are the fans controlled by dom0 or xen in qubesos and does power profiles daemon work on dom0?
