Hello everyone!
I’m currently failing to launch Nextcloud. I installed it in my work templateVM, using
sudo dnf install nextcloud
It seemed to work since when re-running the command it says that it’s already installed. For some reason it didn’t create a .desktop file though.
I created one manually looking like this
[Desktop Entry]
Version=1.0
Name=Nextcloud
GenericName=Cloud Storage
Exec=nextcloud
Icon=nextcloud
Terminal=false
Type=Application
StartupNotify=true
Categories=Network
and placed it inside the /usr/share/applications/ folder.
Now after refreshing the app shortcuts, the nextcloud shortcut shows up (with correct icon and everything). But for some reason I cannot launch it inside my work VM. It just doesn’t do anything.
Did I do anything wrong with the .desktop file? Maybe someone could show me theirs or point me into the right direction concerning Nextcloud setup.
I already created custom .desktop files for other applications and those are working.
Thanks and best regards!
