Nika
1
When I start my signal I get an error saying it cant parse rules for “turn3.voip.signal.org” I look at the firewall rules and it is whitelisted
I’ve changed zero settings in signal. This is not happening to any other appVMs. Any advice would be greatly appreciated
I’ve tried different netVMs and it’s the same problem.
Nika
2
Fixed it by deleting the Qube and creating a new one from the template. Would like to know why it happened if anyone has any insights
same issue here
checked signal.org, and it seems to be correct:
https://support.signal.org/hc/en-us/articles/360007320291-Firewall-and-Internet-settings
could anyone explain how to block the traffic while allowing Signal.Org to work ?
Thanks,
phceac
6
Does the DNS name turn3.voip.signal.org resolve to an address for you? (*)
From here, it does not seem to exist… If it is the same for you, it might explain the parsing failure (to verify).
( * In a connected VM you can do:
host turn3.voip.signal.org
or maybe (if it is installed)
dig turn3.voip.signal.org
NOPE
there is nothing found for this DNS
living and learning - do not trust documentation blindly
thanks for the explanation @phceac
