Failed to copy clipboard (AppVM -> AppVM)
Hi!
I haven’t found any related topic. If there is, please point me to the right direction!
Copy + paste seems working fine using ctrl+shift+c/v, but i just experienced, that i wanted to copy from a disposal VM to a AppVM and it didn’t work. What i did:
  • opened the SteveBlack raw hostfile on github,
  • selected everything using ctrl+a,
  • copied to the clipboard with ctrl+c, than to qubes clipboard with ctrl+shift+c (now it was suspicious that only 1kb data was copied)
  • pasted from qubes clipboard with ctrl+shift+v and pasted to a Template VM’s hosts file opened in gedit, but there was only a “ú” letter copied.
I repeated this 2 or 3 times more, but the result was always the same. Finally i opened the webpage in the default untrusted VM, copy the data to a file, then copied the file to the Template VM.
Could someone help me out why i wasn’t able copy paste from the raw github page?
And just a bonus question:
I had some error in (i think) dom0 and wanted to copy the text from the error message but i wasn’t able to do it. Is it not allowed to copy text from error bubble?
Thanks any help you can provide!
There is a limit on the qvm copy/paste operation of around 64k. You’ve
hit this limit.
The way to copy larger amounts is, as you have discovered, to copy
the file.
(marked unman’s post as the solution and adjusted the title. Feel free to adjust if it doesn’t exactly reflect the issue at hand)
