I really don’t understand this error message and how to fix it. I just ran sudo ./qb template prep with the default arch example config, but it effects every template build. I’m pretty sure that I’m did nothing wrong with importing and trusting the keys. Any ideas what I could done wrong? And how to fix?
Also /builder was empty before.
Running template stages: prep
19:00:21 [qb.fetch.builder-archlinux.fetch] copy-in (cmd): docker cp /tmp/tmpeh7ve6k3/. 0c49fe0458129fd2ad4cdc318d60031460ff75fe7d282cf5c8b41b19c812d0d6:/
19:00:21 [qb.fetch.builder-archlinux.fetch] copy-in (cmd): docker cp /tmp/tmpeh7ve6k3/. 0c49fe0458129fd2ad4cdc318d60031460ff75fe7d282cf5c8b41b19c812d0d6:/builder
19:00:21 [qb.fetch.builder-archlinux.fetch] copy-in (cmd): docker cp /tmp/tmpeh7ve6k3/. 0c49fe0458129fd2ad4cdc318d60031460ff75fe7d282cf5c8b41b19c812d0d6:/builder/plugins
19:00:21 [qb.fetch.builder-archlinux.fetch] copy-in (cmd): docker cp /home/user/qubes-builderv2/qubesbuilder/plugins/fetch 0c49fe0458129fd2ad4cdc318d60031460ff75fe7d282cf5c8b41b19c812d0d6:/builder/plugins
19:00:21 [qb.fetch.builder-archlinux.fetch] Using executor docker:0c49fe045812 to run 'sudo mkdir -p -- /builder /builder/build /builder/plugins /builder/distfiles&&sudo chown -R -- user:user /builder&&cd /builder&&/builder/plugins/fetch/scripts/get-and-verify-source.py https://github.com/qubesos/qubes-builder-archlinux.git /builder/builder-archlinux /builder/keyring /builder/plugins/fetch/keys --git-branch main --minimum-distinct-maintainers 1'.
19:00:23 [qb.fetch.builder-archlinux.fetch] --> Verifying tags...
19:00:23 [qb.fetch.builder-archlinux.fetch] ERROR: CalledProcessError(1, ['git', '-c', 'gpg.program=/usr/bin/gpg', '-c', 'gpg.minTrustLevel=fully', 'verify-tag', '--raw', '--', 'dc64c67f9fa1f7d7aa49294abf42f70615fb087f']); stderr: b'[GNUPG:] NEWSIG\n[GNUPG:] ERRSIG 063938BA42CFA724 1 8 00 1773435478 9 0064428F455451B3EBE78A7F063938BA42CFA724\n[GNUPG:] NO_PUBKEY 063938BA42CFA724\n[GNUPG:] FAILURE gpg-exit 33554433\n'
19:00:23 [qb.fetch.builder-archlinux.fetch] ---> Invalid tag dc64c67f9fa1f7d7aa49294abf42f70615fb087f.
19:00:23 [qb.fetch.builder-archlinux.fetch] Not enough distinct tag signatures. Found 0, mandatory minimum is 1.
19:00:23 [qb] An error occurred: Failed to run 'sudo mkdir -p -- /builder /builder/build /builder/plugins /builder/distfiles&&sudo chown -R -- user:user /builder&&cd /builder&&/builder/plugins/fetch/scripts/get-and-verify-source.py https://github.com/qubesos/qubes-builder-archlinux.git /builder/builder-archlinux /builder/keyring /builder/plugins/fetch/keys --git-branch main --minimum-distinct-maintainers 1' (status=1).
19:00:23 [qb]
File "/home/user/qubes-builderv2/qubesbuilder/cli/cli_base.py", line 107, in __call__
rv = self.main(*args, standalone_mode=False, **kwargs) # type: ignore[call-overload]
File "/usr/lib/python3.14/site-packages/click/core.py", line 1435, in main
rv = self.invoke(ctx)
File "/home/user/qubes-builderv2/qubesbuilder/cli/cli_base.py", line 85, in invoke
return super().invoke(ctx)
File "/usr/lib/python3.14/site-packages/click/core.py", line 1902, in invoke
return _process_result(sub_ctx.command.invoke(sub_ctx))
File "/usr/lib/python3.14/site-packages/click/core.py", line 1933, in invoke
rv.append(sub_ctx.command.invoke(sub_ctx))
File "/usr/lib/python3.14/site-packages/click/core.py", line 1298, in invoke
return ctx.invoke(self.callback, **ctx.params)
File "/usr/lib/python3.14/site-packages/click/core.py", line 853, in invoke
return callback(*args, **kwargs)
File "/usr/lib/python3.14/site-packages/click/decorators.py", line 46, in new_func
return f(get_current_context().obj, *args, **kwargs)
File "/home/user/qubes-builderv2/qubesbuilder/cli/cli_template.py", line 93, in prep
_template_stage(
config=obj.config,
...<2 lines>...
template_timestamp=template_timestamp,
File "/home/user/qubes-builderv2/qubesbuilder/cli/cli_template.py", line 59, in _template_stage
job.run(template_timestamp=template_timestamp)
File "/home/user/qubes-builderv2/qubesbuilder/plugins/fetch/__init__.py", line 173, in run
executor.run(cmd, copy_in, copy_out, environment=self.environment)
File "/home/user/qubes-builderv2/qubesbuilder/executors/container.py", line 286, in run
raise e
File "/home/user/qubes-builderv2/qubesbuilder/executors/container.py", line 257, in run
raise ExecutorError(msg, name=self.container.id)
qubesbuilder.executors.ExecutorError: Failed to run 'sudo mkdir -p -- /builder /builder/build /builder/plugins /builder/distfiles&&sudo chown -R -- user:user /builder&&cd /builder&&/builder/plugins/fetch/scripts/get-and-verify-source.py https://github.com/qubesos/qubes-builder-archlinux.git /builder/builder-archlinux /builder/keyring /builder/plugins/fetch/keys --git-branch main --minimum-distinct-maintainers 1' (status=1).
