Johnboy
September 5, 2024, 6:19am
1
Hello,
I installed the mirage-firewall kernel and try to switch the “Default net qube” in “Qubes OS Global Config” to mirage-firewall.
The same error occurs on cmdline:
qubes-prefs -v default_netvm mirage-firewall
qubes-prefs: error: Failed to access 'default_netvm' property
This could be related to Installation error: sys-firewall / no internet
palainp
September 6, 2024, 6:21am
2
Hello, I’m sorry, I’m currently unable to reproduce your issue
Does that command works for other qubes that provides network (sys-firewall, sys-net, sys-whonix-gw, etc.)?
Johnboy
September 6, 2024, 10:58am
3
No, same error.
I cloned sys-net, deleted sys-net and ran qubesctl state.apply qvm.sys-net as mentioned here:
Well, you’ll also need to set “Net qube” to none,Mode to “HVM”,
disable memory balancing, set “autostart”, adjust memory, and enable clock-sync.
Then you’ll need to attach your NICs, and possibly configure strict
reset.
Alternatively, run :
I suggest you clone the exiting sys-net before deleting it.
Johnboy
September 9, 2024, 3:50am
4
Unfortunately changing a net qube on the fly for a dispVM doesn’t work:
ERROR: Basic tab:
Failed to access 'netvm' property
Strange. Sometimes it works. Sometimes it doesn’t.
Sometimes it works with qvm-prefs, sometimes not -.-
