Thank you everyone.
I did an inplace upgrade to 4.2 following all the steps with no errors. I belive I introduced the error by installing fedora-38, debian-12 and whonix-17 in between pre-reboot and post-reboot steps. I am very stupid.
Running update gui dom0 has no updates, but reports successful update when forced to update instead of saying “no update”.
Running qubes-dom0-update in cli in dom0 I receive this error:
Warning: failed loading ‘/var/lib/qubes/dom0-updates/etc/yum.repos.d/qubes-domo.repo’ , skipping.
UpdateVM is sys-net, and I have changed the templatevm for sys-net to debian-12, fedora-38, fedora-37, debian-11. All have qubes-dom0-update services installed.
Depending on the template I also sometimes see error:
-curl error (37): Couldn’t read a fille file:// file for file:///var/lib/qubes/updates/repodata/repomd.xml
and
Error: failed to download metadata for repo ‘qubes-dom0-cached’: Cannot download repomd.xml: Cannot download repodata/repomd.xml: All mirros were tried
qubes-dom0.repo in yum appears to be structured appropriately, I have switched r$releasever for r4.2 multiple times with no effect. The internet works running any appvm through sys-net.
Finally another error that I don’t remember what I did. For some time in 4.2 I could change Dom0 update proxy in Global Settings, but now when I try to change it a pop up appears saying:
The following error occurred: Failed to set repository data: qrexec call failed: None
This is why I have been changing the sys-net template vm instead of the update proxy vm, I can no longer change the update proxy in global settings.
It is very frustrating because the in place upgrade appeared to go smoothly and I definitely did the damage myself installing things in the middle of the upgrade, very stupid.
Before I backup and reinstall everything from scratch I am hoping there is some fix. If I do reinstall from scratch I should not restore dom0 qubes I imagine, as this appears to be where there is an error?
Thank you again,
Stupid
