JuBrn
1
Hi everybody !
I am a happy qubes os user since 2019.
My objective was to restore the display of messages on boot (instead of the loading animation).
So for that:
- I modified the necessary lines in the file: /etc/default/grub
- then launched the command “grub2-mkconfig -o /boot/efi/EFI/qubes/grubx64.cfg” (efi mode)
- And I restarted to test…
Unable to boot on Qubes OS after this change.
To try to correct the problem I:
- Booted in rescue mode
- Performed a chroot
- Restored the original settings in /etc/default/grub
- Generated a new boot configuration with grub2-mkconfig command
- Check the entry in EFI firmware with efibootmgr -v command is correct
But … still unable to boot
My last idea was to reinstall the grub efi with the command dnf reinstall grub2-efi but I don’t think this is the solution.
Would I have missed something? Do you have any ideas to help me? Thank you in advance for your help!
kommuni
2
Maybe you meant to overwrite grub.cfg with grub2-mkconfig command, but accidentally overwrote grubx64.efi ?
JuBrn
3
Hi, thank you for your reply !
This is a possibility, what should be the approximate size of the .efi? I’ll check.
If it is necessary to reinstall it, how can I do it from rescue mode without a network?
kommuni
4
Approximately 2MB.
It should be possible to generate a custom grub image by referring to the following
qubes-lorax-templates/templates/efi.tmpl at v4.1.11 · QubesOS/qubes-lorax-templates · GitHub
JuBrn
5
It should be possible to generate a custom grub image by referring to the following https://github.com/QubesOS/qubes-lorax-templates/blob/v4.1.11/templates/efi.tmpl#L11-L33
Thank you very much for the information !
How did you find this file in the sources? (I would never have thought to search in qubes-lorax-templates)
But I didn’t understand this line (content of option -p):
-p /EFI/BOOT ${grub_modules}
What is this path?
And is this code valid for version 4.1.2 that I am using?
Wouldn’t it be easier to download the grub2-efi package and install it offline? Or maybe this package doesn’t work for a system like XEN?
kommuni
6
Ah, it should be replaced with /EFI/qubes. It specifies where grub will search by default (for grub.cfg, etc.)
Thus the command would look like:
grub2-mkimage -O x86_64-efi -o ./grubx64.efi -p /EFI/qubes \
all_video boot btrfs cat configfile echo efifwsetup efinet ext2 \
fat font gfxmenu gfxterm gzio halt hfsplus http increment \
iso9660 jpeg loadenv loopback linux lvm lsefi lsefimmap \
mdraid09 mdraid1x minicmd net normal part_apple part_msdos \
part_gpt password_pbkdf2 png reboot search search_fs_uuid \
search_fs_file search_label serial sleep syslinuxcfg test tftp \
video xfs backtrace chain usb usbserial_common usbserial_pl2303 \
usbserial_ftdi usbserial_usbdebug multiboot2
Since Qubes OS’s grub2 is customized, it is better to boot an installation image of the same version as your machine has and use it’s rescue shell.
JuBrn
7
Thanks for your help @kommuni !
