Hey there,
I use a System76 with AMD Ryzen 7 with Qubes 4.1.2. I use them with no issues.
Lately, I had to pump a little bit the resources so I ordered a Tuxedo system with 64GB RAM, Intel Core i9-13900HX and NVIDIA GeForce RTX 4060 8GB (I don’t care about this one because I don’t use its resources).
After installing the Qubes 4.2 on the new system, I have the following problems:
- I can’t use the external monitor (which I use on System76 with Qubes 4.1.2). I set from BIOS to use only Intel GPU and it’s still not working. Shall I try to install a separate driver for Nvidia and set it also in BIOS or?
- I can’t use the keyboard and mouse. I can’t write when Disk password is requested, I can’t write when login password is requested. After logging in, I can use only the mouse after I allow it, but the keyboard is still not working. The same Keyboard and Mouse with the same USB dongle I use on System76 with Q4.1.2 and work.
Out of curiosity, I installed Q4.1.2 and the Keyboard&Mouse problem disappeared which makes me think there is a problem on Q4.2 in handling the USB dongle.
The 2 policies for Mouse and Keyboard are fine:
cat /etc/qubes-rpc/policy/qubes.InputKeyboard
sys-usb dom0 allow
$anyvm $anyvm deny
cat /etc/qubes-rpc/policy/qubes.InputMouse
sys-usb dom0 allow,user=root
$anyvm $anyvm deny
Though, the problem with the monitor(s) still persists in Q4.1.2 as well.
Is there anything that I can try?
