Hello, I recently tried to install QubesOS on my laptop (with a GTX 3060 mobile) and encountered the same issue with the graphics drivers that I used to have on Fedora (booting with a black screen), which required me to blacklist the nouveau driver using the parameter nouveau.modeset=0 in Grub before installation… This workaround worked, and I was able to boot and successfully install QubesOS. However, my external monitor was not being detected, a common issue related to my GPU with Linux distros, requiring the installation of proprietary NVIDIA drivers for my external monitor to be detected. Following this guide (Nvidia driver installation - #2 by dhn) and this guide (Nvidia proprietary driver installation) to install the latest recommended version of the proprietary NVIDIA driver for my GPU (550.90.07 released on June 4th, which worked flawlessly with Linux Mint), I completed the installation successfully, as shown by the commands mentioned in the second referenced guide:
[user@dom0 ~]$ lsmod | grep nvidia
nvidia 60583936 0
[user@dom0 ~]$ lsmod | grep nouveau
[user@dom0 ~]$
Despite this, my external monitor remains undetected, whether I boot with it connected to my laptop or not, the xrandr command output consistently displayed only my laptop’s display, as shown below
xrandr.log:
[user@dom0 ~]$ xrandr
Screen 0: minimum 320 x 200, current 1920 x 1080, maximum 16384 x 16384
eDP-1 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 344mm x 194mm
1920x1080 144.00*+ 60.01 59.97 59.96 60.00 59.93
1680x1050 59.95 59.88
1400x1050 74.76 59.98
1600x900 59.99 59.94 59.95 59.82
1280x1024 85.02 75.02 60.02
1400x900 59.96 59.88
1280x960 85.00 60.00
1440x810 60.00 59.97
1368x768 59.88 59.85
1280x800 59.99 59.97 59.81 59.91
1152x864 75.00
1280x720 60.00 59.99 59.86 59.74
1024x768 85.00 75.05 60.04 85.00 75.03 70.07 60.00
1024x768i 86.96
960x720 85.00 75.00 60.00
928x696 75.00 60.05
896x672 75.05 60.01
1024x576 59.95 59.96 59.90 59.82
960x600 59.93 60.00
832x624 74.55
960x540 59.96 59.99 59.63 59.82
800x600 85.00 75.00 70.00 65.00 60.00 85.14 72.19 75.00 60.32 56.25
840x525 60.01 59.88
864x486 59.92 59.57
700x525 74.76 59.98
800x450 59.95 59.82
640x512 85.02 75.02 60.02
700x450 59.96 59.88
640x480 85.09 60.00 85.01 72.81 75.00 59.94
720x405 59.51 58.99
720x400 85.04
684x384 59.88 59.85
640x400 59.88 59.98 85.08
576x432 75.00
640x360 59.86 59.83 59.84 59.32
640x350 85.08
512x384 85.00 75.03 70.07 60.00
512x384i 87.06
512x288 60.00 59.92
416x312 74.66
480x270 59.63 59.82
400x300 85.27 72.19 75.12 60.32 56.34
432x243 59.92 59.57
320x240 85.18 72.81 75.00 60.05
360x202 59.51 59.13
360x200 85.04
320x200 85.27
320x180 59.84 59.32
320x175 85.27
[user@dom0 ~]$
I have experimented with various kernel versions and different NVIDIA driver versions on previous clean QubesOS installations, yet the issue persisted. I am unsure of what steps to take next. Can someone assist me in identifying the root cause and finding a solution to this problem?
