To secure communications over Mumble, you should control the machine on which the Mumble server is running. You can run the server locally and expose it to the world through VPS using wireguard.
You need to setup Wireguard on your VPS and locally first. See this guide. Create a separate qube for Mumble server and do local part of the guide in it.
Let’s say your mumble qube has Wireguard IP 192.168.66.10 and your VPS has external IP 1.2.3.4 and network interface eth0. Mumble server (murmurd) is running on port 64738 locally, but let’s say you want to expose it at port 1.2.3.4:3333.
Port forwarding
On VPS run the following:
# iptables -t nat -A PREROUTING -i eth0 -p udp -m udp --dport 3333 -j DNAT --to-destination 192.168.66.10:64738
# iptables -t nat -A PREROUTING -i eth0 -p tcp -m tcp --dport 3333 -j DNAT --to-destination 192.168.66.10:64738
Make sure to forward both UDP and TCP. It won’t work without TCP and it will work slower without UDP.
In mumble qube:
sudo iptables -I INPUT 1 -p tcp -m tcp --dport 64738 -j ACCEPT
sudo iptables -I INPUT 1 -p udp -m udp --dport 64738 -j ACCEPT
Install Mumble server
In mumble qube:
sudo apt-get install -y mumble-server
You can configure it using sudo dpkg-reconfigure mumble-server or set password in /etc/mumble-server.ini (variable serverpassword) and run sudo service mumble-server restart.
Then connect from all Mumble clients through endpoint 1.2.3.4:3333. It should work at this point.
Making the server persistent
Qubes removes all system files when a qube is restarted. If you install Mumble server from scratch every time, it won’t remember any configuration, rooms, registered users, etc. Also clients will show a warning about new key.
So you should either make the qube standalone or use the following trick.
All the files you need to preserve are the following:
- /etc/mumble-server.ini
- /var/lib/mumble-server/mumble-server.sqlite
Finish configuration and connect from all expected clients and then stop the server:
$ sudo service mumble-server stop
and save the files in home directory:
$ sudo cp /etc/mumble-server.ini /var/lib/mumble-server/mumble-server.sqlite /home/user
Now you can restart the qube. After that you can run the following script to start the server:
set -x
sudo cp /home/user/mumble-server.ini /etc/mumble-server.ini
sudo cp /home/user/mumble-server.sqlite /var/lib/mumble-server/mumble-server.sqlite
sudo service mumble-server start
- Page archive
- First commit: 22 Apr 2021. Last commit: 22 Apr 2021.
- Applicable Qubes OS releases based on commit dates and supported releases: 4.0
- Original author(s) (GitHub usernames): ratpoison4
- Original author(s) (forum usernames): N/A
- Document license: GPLv2
