Experiences with default 1 VCPU?
I’ve started limiting each VM to 1 VCPU (e.g., xl vcpu-set sys-firewall 1 to take effect now, qvm-prefs sys-firewall vcpus 1 for next restart of the VM) in the hope of mitigating concurrency-related vulnerabilities in software that spins up one thread per VCPU. I wonder whether other people have tried this already and encountered any issues with it.
Which vulnerabilities are you referring to?
For example, maybe this would have mitigated CVE-2026-98432. But the point is broader than any particular bug; the point is that it’s common for software to (1) spin up one thread per OS-announced core and (2) have bugs with multiple threads that can’t occur when there’s only one thread.
CVE-2026-98432 not applicable to Qubes OS. Regardless, limiting to 1 vCPU is advisable to improve CPU ready time, battery/power efficiency, and ensure CPU availability for other Qubes that request it.
Software can have bugs in a single thread too. I doubt VCPU was invented to protect from buggy software.
I’ve been using 1 vcpu on most of my sys- qubes without issue. It even improves the performance of the rest of the system, as stated by @WhiteShadow
While this issue was hopefully solved:
Just be aware that some apps might not like the single CPU VM’s :slight_smile:
Other that that, I also used to run my sys-* VM’s on a single vCPU.
