I have a standalone HVM running kicksecure. The original private storage max size was 10G, but I’m running out of space. I increased the private storage max size, but it appears Qubes added a new disk, and did not expand the original.
[sysmaint ~]% lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
xvda 202:0 0 10G 0 disk
├─xvda1 202:1 0 2G 0 part /boot
└─xvda2 202:2 0 8G 0 part
└─luks-XXX-XXX-XXX 254:0 0 8G 0 crypt /
xvdb 202:16 0 60G 0 disk
xvdc 202:32 0 10G 0 disk
[sysmaint ~]%
How would I remove the /dev/xvd{b,c} disks, and have a single xvda disk with the boot and encrypted partitions?
The numbers indicate the disk partitions. In your case, the numbers indicate the partitions on the xvda disk. The xvdb disk has no partitions.
Increasing the private storage will resize xvdb. However, if you want to increase the size of xvda2, you will need to resize the system storage, and then resize xvda2 manually in the HVM.
As a test, I created a new vm and started the ISO install process. My previous statement about there only being one disk was wrong. During the partitioning phase, I’m presented with 3 detected disks, xvda/b/c. If xvda is system storage, and xvdb is private storage, what is xvdc for?
Thank you for linking that, definitely fills in some gaps, but there is still some confusion on my part.
Per the doc:
private.img (xvdb)
This is mounted as /rw and here is placed all VM private data. This includes:
/home – which is bind mounted to /rw/home
/usr/local – which is symlink to /rw/usrlocal
some config files (/rw/config) called by qubes core scripts (ex /rw/config/rc.local)
But how can this be if xvdb does not have a partition and is currently just unallocated space?
Ultimately what it seems I’m trying to do, is create a luks encrypted partition on xvdb containing /home and have it unlocked at boot time and mounted. Is that accurate?
Since you are using a HVM Standalone, xvdb is not used because all the data are located in xvda.
The /home directory is already in the LUKS partition that you created during installation. There is no need to complicate the setup by using the other disk.
Are you using the HVM Standalone setup to get an encrypted disk? It would be much easier to use the community template.
I’m using the HVM standalone because I need a GUI environment.
The issue I’m currently facing is xvda is too small. From what I understand, I should be increasing the max system storage size, which would expand xvda.
