I’m persistently encountering errors in my appvms that center around access to their virtual block devices. Here’s an example of a typical guest kernel log:
[2025-03-16 00:08:16] [87388.333033] audit: type=1334 audit(1742098096.665:178): prog-id=65 op=LOAD
[2025-03-16 00:08:16] [87388.376073] audit: type=1130 audit(1742098096.708:179): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=unbound-anchor comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[2025-03-16 00:08:16] [87388.376107] audit: type=1131 audit(1742098096.708:180): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=unbound-anchor comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[2025-03-16 00:08:16] [87388.390928] audit: type=1130 audit(1742098096.723:181): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=logrotate comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[2025-03-16 00:08:16] [87388.390968] audit: type=1131 audit(1742098096.723:182): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=logrotate comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[2025-03-16 00:08:16] [87388.394939] audit: type=1130 audit(1742098096.727:183): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[2025-03-16 00:08:16] [87388.394976] audit: type=1131 audit(1742098096.727:184): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[2025-03-16 00:08:16] [87388.411757] audit: type=1334 audit(1742098096.744:185): prog-id=65 op=UNLOAD
[2025-03-16 00:27:41] [88553.111577] audit: type=1334 audit(1742099261.444:186): prog-id=66 op=LOAD
[2025-03-16 00:27:41] [88553.111836] audit: type=1334 audit(1742099261.445:187): prog-id=67 op=LOAD
[2025-03-16 00:27:41] [88553.111884] audit: type=1334 audit(1742099261.445:188): prog-id=68 op=LOAD
[2025-03-16 00:27:41] [88553.111906] audit: type=1334 audit(1742099261.445:189): prog-id=57 op=UNLOAD
[2025-03-16 00:27:41] [88553.111932] audit: type=1334 audit(1742099261.445:190): prog-id=58 op=UNLOAD
[2025-03-16 00:27:41] [88553.155078] audit: type=1130 audit(1742099261.488:191): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[2025-03-16 00:27:41] [88553.613202] audit: type=1334 audit(1742099261.946:192): prog-id=69 op=LOAD
[2025-03-16 00:27:41] [88553.613279] audit: type=1334 audit(1742099261.946:193): prog-id=70 op=LOAD
[2025-03-16 00:27:41] [88553.613309] audit: type=1334 audit(1742099261.946:194): prog-id=71 op=LOAD
[2025-03-16 00:27:41] [88553.614426] FAT-fs (xvda1): bogus number of reserved sectors
[2025-03-16 00:27:41] [88553.614443] FAT-fs (xvda1): Can't find a valid FAT filesystem
[2025-03-16 00:27:41] [88553.618552] audit: type=1130 audit(1742099261.951:195): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=pcscd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[2025-03-16 00:28:11] [88583.248271] kauditd_printk_skb: 1 callbacks suppressed
[2025-03-16 00:28:11] [88583.248277] audit: type=1131 audit(1742099291.581:197): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[2025-03-16 00:28:11] [88583.283817] audit: type=1334 audit(1742099291.617:198): prog-id=66 op=UNLOAD
[2025-03-16 00:28:12] [88583.664295] audit: type=1131 audit(1742099291.997:199): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[2025-03-16 00:28:12] [88583.676908] audit: type=1334 audit(1742099292.010:200): prog-id=71 op=UNLOAD
[2025-03-16 00:28:12] [88583.676968] audit: type=1334 audit(1742099292.010:201): prog-id=70 op=UNLOAD
[2025-03-16 00:28:12] [88583.677011] audit: type=1334 audit(1742099292.010:202): prog-id=69 op=UNLOAD
[2025-03-16 05:56:16] [108268.330704] audit: type=1130 audit(1742118976.675:203): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=raid-check comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[2025-03-16 05:56:16] [108268.330809] audit: type=1131 audit(1742118976.675:204): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=raid-check comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[2025-03-16 05:56:17] [108268.583076] audit: type=1130 audit(1742118977.055:205): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=qubes-sync-time comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[2025-03-16 05:56:17] [108268.583171] audit: type=1131 audit(1742118977.055:206): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=qubes-sync-time comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[2025-03-16 11:16:28] [127480.393831] I/O error, dev xvda, sector 18204816 op 0x0:(READ) flags 0x80700 phys_seg 6 prio class 0
[2025-03-16 11:16:28] [127480.396712] I/O error, dev xvda, sector 5469048 op 0x0:(READ) flags 0x80700 phys_seg 8 prio class 0
[2025-03-16 11:16:28] [127480.400048] I/O error, dev xvda, sector 17496608 op 0x1:(WRITE) flags 0x9800 phys_seg 2 prio class 2
[2025-03-16 11:16:28] [127480.400076] Aborting journal on device xvda3-8.
[2025-03-16 11:16:28] [127480.402710] I/O error, dev xvda, sector 17455104 op 0x1:(WRITE) flags 0x9800 phys_seg 1 prio class 2
[2025-03-16 11:16:28] [127480.402755] I/O error, dev xvda, sector 17455104 op 0x1:(WRITE) flags 0x9800 phys_seg 1 prio class 2
[2025-03-16 11:16:28] [127480.402770] Buffer I/O error on dev xvda3, logical block 2129920, lost sync page write
[2025-03-16 11:16:28] [127480.402793] JBD2: I/O error when updating journal superblock for xvda3-8.
[2025-03-16 11:16:28] [127480.402830] EXT4-fs error (device xvda3): ext4_journal_check_start:84: comm systemd-journal: Detected aborted journal
[2025-03-16 11:16:28] [127480.416779] EXT4-fs (xvda3): Remounting filesystem read-only
[2025-03-16 11:16:28] [127480.416967] I/O error, dev xvda, sector 5465232 op 0x0:(READ) flags 0x80700 phys_seg 8 prio class 0
[2025-03-16 11:16:28] [127480.420057] I/O error, dev xvda, sector 5463048 op 0x0:(READ) flags 0x80700 phys_seg 32 prio class 0
[2025-03-16 11:16:29] [127480.558017] I/O error, dev xvdc, sector 858112 op 0x1:(WRITE) flags 0x1004000 phys_seg 32 prio class 0
[2025-03-16 11:16:29] [127480.558051] Write-error on swap-device (202:32:858112)
[2025-03-16 11:16:29] [127480.558069] Write-error on swap-device (202:32:858120)
[2025-03-16 11:16:29] [127480.558083] Write-error on swap-device (202:32:858128)
[2025-03-16 11:16:29] [127480.558096] Write-error on swap-device (202:32:858136)
[2025-03-16 11:16:29] [127480.558109] Write-error on swap-device (202:32:858144)
[2025-03-16 11:16:29] [127480.558122] Write-error on swap-device (202:32:858152)
[2025-03-16 11:16:29] [127480.558214] Write-error on swap-device (202:32:858160)
[2025-03-16 11:16:29] [127480.558230] Write-error on swap-device (202:32:858168)
[2025-03-16 11:16:29] [127480.558243] Write-error on swap-device (202:32:858176)
[2025-03-16 11:16:29] [127480.558257] Write-error on swap-device (202:32:858184)
[2025-03-16 11:16:29] [127480.560731] I/O error, dev xvdc, sector 730960 op 0x1:(WRITE) flags 0x1000000 phys_seg 22 prio class 0
This occurs in all of my appvms, but there is notably no trace of any problem in dom0 (I’ve checked the kernel logs, systemd logs, btrfs stats on dom0, and I’ve scrubbed the dom0 drives containing pools in question).
A few stats on my system:
- Qubes 4.2.3
- Btrfs filesystems in dom0
- Modified Fedora 40 xfce templates (modifications mainly involve additional software and UI scaling)
What I’ve tried:
- Various combinations of memory ballooning, virtualization mode, guest kernel.
- Upgraded
qubes-utilsfrom 4.2.17 to 4.2.19 and confirmed that direct I/O went from being enabled to being disabled (to rule out that my issue was related to Disable direct IO on Btrfs based storage #9488).
There seems to be some correlation to memory pressure, since the errors appear on the appvms with the lowest memory. On VMs with ample memory, the errors still occur, but with lower frequency. Swap use doesn’t seem to be a necessary condition.
At this point, I suspect there’s an issue with xen, xen_blkback, and/or xen_blkfront. Any advice on how to debug this problem further would be greatly appreciated.
