Would somone provide help with evaluating errors returned during an upgrade from Fedora-30 to Fedora-32?
It takes awhile for the dnf command to complete so I was hoping for help. The last two look as if I may not have a repository configured correctly, but that’s a wild guess.
Thanks
Using “Upgrading Fedora TemplateVMs” as a reference (1), running the following command:
[user@fedora-32 ~]$ sudo dnf --releasever=32 --setopt=cachedir=/mnt/removable --best --allowerasing distro-sync
returned the following errors: (For brevity, ellipses (…) designate skipped output)
Running transaction
Running scriptlet: qubes-kernel-vm-support-4.0.30-1.fc30.x86_64 1493/2899
Error! DKMS: Remove cancelled because --rpm_safe_upgrade scenario detected.
Cleanup : qubes-kernel-vm-support-4.0.30-1.fc30.x86_64 1493/2899
Cleanup : NetworkManager-1:1.16.4-1.fc30.x86_64 2075/2899
Running scriptlet: NetworkManager-1:1.16.4-1.fc30.x86_64 2075/2899
Failed to wait for daemon to reply: Broken pipe
Cleanup : glibc-2.29-29.fc30.x86_64 2886/2899
Running scriptlet: glibc-2.29-29.fc30.x86_64 2886/2899
/var/tmp/rpm-tmp.IT2iKC: line 5: /sbin/sln: No such file or directory
Running scriptlet: qubes-kernel-vm-support-4.0.30-1.fc32.x86_64 2899/2899
dracut: Cannot find module directory /lib/modules/*/
dracut: and --no-kernel was not specified
Errors during downloading metadata for repository ‘fedora-cisco-openh264’:
- Curl error (6): Couldn’t resolve host name for https://mirrors.fedoraproject.org/metalink?repo=fedora-cisco-openh264-32&arch=x86_64 [Could not resolve host: mirrors.fedoraproject.org]
Error: Failed to download metadata for repo ‘fedora-cisco-openh264’: Cannot prepare internal mirrorlist: Curl error (6): Couldn’t resolve host name for https://mirrors.fedoraproject.org/metalink?repo=fedora-cisco-openh264-32&arch=x86_64 [Could not resolve host: mirrors.fedoraproject.org]
Errors during downloading metadata for repository ‘fedora-modular’: - Curl error (6): Couldn’t resolve host name for https://mirrors.fedoraproject.org/metalink?repo=fedora-modular-32&arch=x86_64 [Could not resolve host: mirrors.fedoraproject.org]
Error: Failed to download metadata for repo ‘fedora-modular’: Cannot prepare internal mirrorlist: Curl error (6): Couldn’t resolve host name for https://mirrors.fedoraproject.org/metalink?repo=fedora-modular-32&arch=x86_64 [Could not resolve host: mirrors.fedoraproject.org]
[user@fedora-32 ~]$
