When I try to update my debian or whonix templates using either qubes-update-gui or sudo qubesctl --show-output --skip-dom0 --targets=<mytemplate> state.sls update.qubes-vm, I get: “: ERROR (exception list index out of range)”.
I end up having to run the update manually.
This started about a week ago.
Is there a log with more information so I can debug this?
Besides having the same problem, I can’t update manually:
$ sudo apt update
Err:3 https://deb.qubes-os.org/r4.0/vm buster InRelease
Reading from proxy failed - select (115: Operation now in progress) [IP: 127.0.0.1 8082]
Fetched 65.4 kB in 30s (2,176 B/s)
Reading package lists… Done
Building dependency tree
Reading state information… Done
All packages are up to date.
W: Failed to fetch https://deb.qubes-os.org/r4.0/vm/dists/buster/InRelease Reading from proxy failed - select (115: Operation now in progress) [IP: 127.0.0.1 8082]
W: Some index files failed to download. They have been ignored, or old ones used instead.
I have the same issue, but I suspect mine stems from my debian-minimal templates (including the debian default-mgmt-dvm template) not having the appropriate Salt packages installed. Try installing them according to the docs and see if it works.
It’s worth nothing that I was experiencing airelemental’s issue long before experiencing sandworm’s issue, below:
I have the exact same issue. One stop-gap measure that works is to route all updates through tor.
Update: My issue was limited to the Qubes repo and fails with the Index of /qubes/repo/deb/r4.0/vm/ link. After I updated my firewall, the problem went away even on non-tor connections.
I wonder why it worked on tor before I fixed the updateVM’s firewall?
