I purchased a certified copy of a bootable QubesOS USB stick.
I want to clone the certified Qubes USB onto a more compact USB stick.
Both the original and the compact USB sticks are 32 GB in size.
I ran the following command:
sudo dd if=/dev/sdb of=/dev/sda status=progress bs=1048576 conv=fsync
After a significant delay, I got the following error:
30778851328 bytes (31 GB, 29 GiB) copied, 4584 s, 6.7 MB/s
dd: error writing '/dev/sda': No space left on device
29359+0 records in
29358+0 records out
30784094208 bytes (31 GB, 29 GiB) copied, 4692.9 s, 6.6 MB/s
What should I have done to avoid the error message?
