I bought a small 11 inch notebook of an older model. Now I have got Qubes installed installation gave an error, I can not start hvm because my hardware does not support IOMMU/TV-d/AMD-vi.
Okay, I finished the installation and at startup all VM are off. Can’t start any, then the error message comes up again.
I only found the point in the bios:
Intel Virtual Technology and I set it to enabled
Okay now my question, can I change something or can I forget the laptop for cubes?
I wanted to use it for serving without big tasks but with the security of cubes. I already use Cubes on several computers, but this is the first time I have encountered such a problem.
You should be able to run Qubes. The CPU supports both VT-x (+ EPT) and VT-d, which are required for Qubes to work properly. You should check your BIOS for anything related to these features and see if they are enabled or not.
Well, this means that VT-d (IOMMU) is not working or is not enabled.
You should go back into your BIOS and make sure everything is enabled properly. You can use this.
Turn off the laptop completely and boot it up again after making sure everything is enabled.
If this still does not help, see if you can update your BIOS firmware to a newer version.
okay thanks. there is a newer bios version, but I need Windows for that. I’ll install win, update the bios and see if I get the functions I want and get back to you. Thanks for now
so thank you very much. The solution was to update the bios. The description also included the correction of virtualization errors.
That must have been it. Now I can set up Quebes
