I am trying to install the v4l2loopback-dkms
package in a debian-10
qube.
My debian-10
qube has kernel version 5.4.98-1.fc25
During installation it builds the module for kernel versions 4.19.0-13-amd64
, 4.19.0-20-amd64
, and 5.4.98-1.fc25
, though I’m not sure why.
The 4.19
builds succeed, but the 5.4.98-1.fc25
build fails. From the make.log
DKMS make.log for v4l2loopback-0.12.1 for kernel 5.4.98-1.fc25.qubes.x86_64 (x86_64)
Fri 06 May 2022 11:32:13 AM EDT
Building v4l2-loopback driver...
make -C /lib/modules/5.4.98-1.fc25.qubes.x86_64/build M=/var/lib/dkms/v4l2loopback/0.12.1/build modules
make[1]: Entering directory '/usr/lib/modules/5.4.98-1.fc25.qubes.x86_64/build'
CC [M] /var/lib/dkms/v4l2loopback/0.12.1/build/v4l2loopback.o
/var/lib/dkms/v4l2loopback/0.12.1/build/v4l2loopback.c: In function ‘vidioc_qbuf’:
/var/lib/dkms/v4l2loopback/0.12.1/build/v4l2loopback.c:1509:4: error: implicit declaration of function ‘v4l2_get_timestamp’; did you mean ‘v4l2_get_subdevdata’? [-Werror=implicit-function-declaration]
v4l2_get_timestamp(&b->buffer.timestamp);
v4l2_get_subdevdata
cc1: some warnings being treated as errors
make[2]: *** [scripts/Makefile.build:262: /var/lib/dkms/v4l2loopback/0.12.1/build/v4l2loopback.o] Error 1
make[1]: *** [Makefile:1726: /var/lib/dkms/v4l2loopback/0.12.1/build] Error 2
make[1]: Leaving directory '/usr/lib/modules/5.4.98-1.fc25.qubes.x86_64/build'
make: *** [Makefile:43: v4l2loopback.ko] Error 2
Any suggestions on how to deal with this problem?
Can I create a debian-10
using a 4.19...
kernel to solve this?
