When installing Qubes I opted to use sys-net for both networking and usb. I now want to create a dedicated sys-usb but when I run sudo qubesctl state.sls qvm.sys-usb in dom0 I get an error. The sys-net state is entirely in red and says:
Function: qvm.prefs
Result: False
Comment: The following requisites were not found:
require:
sls: qvm.sys-net
At the end of the output I get
Summary for local
Succeeded: 3
Failed: 1
Total states run: 4
Total run time: 496.791 ms
DOM0 configuration failed, not continuing
The states that succeeded are hide-usb-from-dom0-uefi, qubes-input-proxy and sys-usb-input proxy
I’ve tried running the command with sys-net shut down but I get the same result.
Thank you for any help.
EDIT: Qubes is installed on a laptop. Both keyboard and trackpad work with sys-net disabled so there is no risk of locking myself out. My goal here is to create a sys-usb VM and pass through my mouse to dom0 while continuing to use my build in keyboard for now. I also want to improve my security by shielding sys-net from all plugged in USB devices.
