I followed the Whonix wiki on “onionizing” repositories, for Fedora they mention that once should:
Note: Updating Fedora templates exclusively over Onion Services is not possible – only related Qubes repositories can be onionized. The reason is Fedora does not maintain onion service repositories.
‘’‘1.’‘’ In Fedora Template, open the qubes-r4.repo file in a text editor. At the time of writing Qubes-R4 was the current stable release.
sudo gedit /etc/yum.repos.d/qubes-r*.repo
uncomment the lines that contain Qubes_onion
Once completed, each of the four code blocks will have http(s) repository lines similar to the following example.
‘’‘2.’‘’ In Fedora Template, confirm the onion service repositories are functional.
sudo dnf update
The problem is that after I did that step and tried to download a specific package from the Qubes repositories for testing purposes I was met with this error:
[MIRROR] libxdo-3.20210804.2-2.fc35.x86_64.rpm: Curl error (6): Couldn't resolve host name for http://yum.qubesosfasa4zl44o4tws22di6kepyzfeqv3tg4e3ztknltfxqrymdad.onion/r4.1/current/vm/fc35/rpm/libxdo-3.20210804.2-2.fc35.x86_64.rpm [Could not resolve host: yum.qubesosfasa4zl44o4tws22di6kepyzfeqv3tg4e3ztknltfxqrymdad.onion]
[FAILED] libxdo-3.20210804.2-2.fc35.x86_64.rpm: No more mirrors to try - All mirrors were already tried without success
(22-23/29): qt5-qtto 42% [========- ] 158 MB/s | 13 MB 00:00 ETA
The downloaded packages were saved in cache until the next successful transaction.
You can remove cached packages by executing 'dnf clean packages'.
Error: Error downloading packages:
libxdo-1:3.20210804.2-2.fc35.x86_64: Cannot download, all mirrors were already tried without success
I don’t know how to fix it. I already have a package such as torsocks installed. Also in the Qubes Global Settings I have sys-whonix as the default dom0 update qube.
[user@test-vm ~]$ sudo dnf update
Qubes OS Repository for VM (updates) 0.0 B/s | 0 B 00:00
Errors during downloading metadata for repository 'qubes-vm-r4.1-current':
- Curl error (6): Couldn't resolve host name for http://yum.qubesosfasa4zl44o4tws22di6kepyzfeqv3tg4e3ztknltfxqrymdad.onion/r4.1/current/vm/fc35/repodata/repomd.xml [Could not resolve host: yum.qubesosfasa4zl44o4tws22di6kepyzfeqv3tg4e3ztknltfxqrymdad.onion]
Error: Failed to download metadata for repo 'qubes-vm-r4.1-current': Cannot download repomd.xml: Cannot download repodata/repomd.xml: All mirrors were tried
Do you have tor running inside these debian-11 AppVM? Maybe you installed tor package in debian template?
In that case if you tor-over-tor connection if you use debian AppVM with sys-whonix netvm.
