Hi there,
I think it may be more useful if HCL is downloadable (also as a csv), for organizing purpose.
I think people may be interested more in latest hw supported by latest release of Qubes, instead of simple alphabetical one.
What do You think?
Cheers,
M.
You already have the option to download the .yml: GitHub - QubesOS/qubes-hcl: HCL reports for Qubes OS Project
It’s easy to then convert it to csv if you so require.
Did you know that you can click on the column headings to sort by that column?
Hi there,
yes, thanks… but only 1 column by time. In a spreadsheet You can sort by more column…
I mean… I think may be useful…
That’s all
Cheers,
M.
I agree this would be a great feature and plan to work on that when I got a little time (maybe over the holidays).
When searched for my current hardware, couple of years ago I copy/pasted HCL list to Calc and manipulated further with it…
This script might be a good start. Just download the yaml and process it like the below script. The column names would be different of course. Maybe add a wget function to do this in one step.
