Dang – I had expected them to differ and the solution to be to have the GRUB config match the blkid
The number of lines depends on the number of kernels installed …
i just ran blkid again and it gave me tons of lines of templates /dev/mapper/qubes_dom0
i think we may have solved it. Should I reboot and try? or what to do next?
i also see the name of the templates I custom created.
When I ran blkid | grep -i luks
I only see two lines
/dev/sdb3 UUID:
/dev/mapper/luks-UUID
Can you try:
cryptsetup luksOpen /dev/sdb3 myTest
This will ask for your password in order to unlock your LUKS volume – does that work?
after command
i type the password, it says,
"cannot use device /dev/sdb3 which is in use (already mapped or mounted)
Oh - I didn’t know you had unlocked it already … in that case, it could make sense to try and reboot.
Also: I’m about out of ideas for what can be the problem … so a reboot and see how it goes, is one of my last suggestions. :-/
i tried the reboot. it takes a long time to load and doesn’t ask for password. it just took me to the black screen and says
warning /dev/mapper/qubes_dom0-root does not exist
“Warning: Not all disks have been found.”
“Warning: You might want to regenerate your initramfs”
so doesn’t look like we were able to fix it yet.
I do remember trying the same process as you did before with some other guides. I did do a mkdir before is there a way to find if i maybe mounted it somewhere else? and I can continue where I left off
I loaded rescue disk, i went to shell (without typing in password for sdb3) and typed command
blkid
I got a different UUID for each dev/sdb1, sdb2, and sdb3. the sdb3 UUID is the same as the previous steps we did early on. The other ones are different UUID’s for sdb1 and 2
Do you have telegram so I can show you screenshots?
If it doesn’t ask for the password for the LUKS encrypted volume, then it make sense that /dev/mapper/qubes_dom0-root
is missing – it shoul only be available, after the password has been entered.
Can you try to edit the GRUB command line and remove the quiet
and see how the boot goes?
I clicked E for edit and under module 2 i see rhgb quiet. Should I remove that?
When I remove it and press F10 to boot, it loads large lines of commands and few minutes later it will not boot successfully. I think I should try doing the steps you suggested without using the password to sdb3? just directly go to shell and try the commands?
there has to be a solution for this. I cant possibly be the only person with this problem. It was working one day, then next day i started getting these boot errors.
@ChrisA can you look at this for me? anaconda rescue is broken · Issue #5609 · QubesOS/qubes-issues · GitHub
A really quick & dirty ad-hoc workaround would be to
rename all find_existing_installations to _find_existing_installations in the /usr/lib*/python*/site-packages/pyanaconda/rescue.py file and then re-run anaconda rescue: anaconda --rescue --lang us
I don’t understand how I would proceed with these steps? Do I type this in shell? or how do I get it done? what is the commands?
When did the error start appearing?
Unplanned shutdown, or out of diskspace errors?
Edit:
Is it possible you ran out of disk space?
I think I may have encountered this before.
What I did to solve it was delete some Qubes that could easily be restored.
Are you only able to boot into the shell from the USB stick?
ah yes, that could have happened. I am not sure how though because it has 180gb on the main sdb3 drive. How can I delete one or two of my custom created qubes?
Yes, i can load into shell with the original usb stick i use to boot into it or a second usb with the recovery option.
You can check them out as reported “here”.
Of course, You have first of all boot from usb, luksOpen your sd<X>3 partition, then run lsblk to get which are your deletable VMs.
Cheers,
M.
can I get step by step instructions please?
I find it so rude to ignore people and poking others.
