Now I’m very happy. This should make my life easier.
I tend to do all kinds of tests and coding in disposable templates and creating qubes.ConnectTCP-pipes is a PITA, so finally made myself a little dev-tool.
It lists all the VMs with services they are running on localhost so that I can create those TCP pipes and related policy rules with just point and click. Policies are saved to /etc/qubes/policy.d/30-dev-tcp-temp.policy
These are intended to be temporary, so everything is cleaned afterwards when interrupted or closed, it removes all the socat pipes and added policies.
It’s still not very polished or battle tested but basic functionality seems to work just fine.
Now, installing things to dom0 is not recommended and I’m not advising anyone to use this. You probably shouldn’t.
It requires this package:
sudo qubes-dom0-update python3-tkinter
qube_pipes.py
#!/usr/bin/python3
import tkinter as tk
from tkinter import messagebox
import subprocess
import signal
import atexit
import os
import sys
import threading
import time
import qubesadmin
# Configuration
POLICY_FILE = "/etc/qubes/policy.d/30-dev-tcp-temp.policy"
EXCLUDED_VMS = ["dom0", "mirage-firewall", "snitch-ui", "vault"]
# Visual Theme
THEME = {
"bg": "#F0F2F5", # Main canvas background
"panel_bg": "#FFFFFF", # Top bar background
"text_main": "#333333", # Standard text
"text_muted": "#666666", # Instructions text
"vm_bg": "#FFFFFF", # VM Card background
"vm_border": "#CED4DA", # VM Card border
"vm_sel_bg": "#E7F1FF", # Selected VM background
"vm_sel_border": "#0D6EFD", # Selected VM border
"port_fill": "#20C997", # Port circle
"port_border": "#198754", # Port border
"line": "#0D6EFD", # Connection line
FONT_MAIN = ("Helvetica", 10)
FONT_BOLD = ("Helvetica", 10, "bold")
FONT_LARGE = ("Helvetica", 11)
class VM:
def __init__(self, name, x, y):
self.name = name
self.x = x
self.y = y
self.ports = []
self.canvas_id = None
self.port_ids = {} # port -> canvas item ID
def update_ports(self, ports):
self.ports = ports
class Connection:
def __init__(self, client_name, local_port, server_name, remote_port):
self.client_name = client_name
self.local_port = local_port
self.server_name = server_name
self.remote_port = remote_port
self.line_id = None
self.process = None
class QubePipesApp:
def __init__(self, root):
self.root = root
self.root.title("Qubes TCP Pipes")
self.root.configure(bg=THEME["bg"])
# --- UI Layout ---
# Top Control Panel
self.top_frame = tk.Frame(root, bg=THEME["panel_bg"], height=50, bd=1, relief=tk.RIDGE)
self.top_frame.pack(fill=tk.X, side=tk.TOP)
self.refresh_btn = tk.Button(
self.top_frame, text="⟳ Refresh VMs", command=self.refresh_vms,
bg="#F8F9FA", activebackground="#E2E6EA", relief=tk.GROOVE, padx=10
self.refresh_btn.pack(side=tk.LEFT, padx=15, pady=10)
instructions = tk.Label(
self.top_frame,
text="1. Click a VM box to select Client | 2. Click a green port on another VM to connect",
bg=THEME["panel_bg"], fg=THEME["text_muted"], font=FONT_LARGE
instructions.pack(side=tk.LEFT, padx=20)
# Main Canvas
self.canvas = tk.Canvas(root, width=1200, height=800, bg=THEME["bg"], highlightthickness=0)
self.canvas.pack(fill=tk.BOTH, expand=True)
# --- State Variables ---
self.vms = {}
self.connections = []
self.selected_source_vm = None
self.setup_signals()
self.refresh_vms()
self.canvas.bind("<Button-1>", self.on_click)
self.canvas.bind("<Button-3>", self.on_right_click)
self.canvas.bind("<Configure>", self.on_resize)
self.last_width = self.root.winfo_width()
def setup_signals(self):
signal.signal(signal.SIGINT, self.handle_exit)
signal.signal(signal.SIGTERM, self.handle_exit)
self.root.protocol("WM_DELETE_WINDOW", self.handle_exit_gui)
atexit.register(self.cleanup)
def handle_exit(self, signum, frame):
self.cleanup()
sys.exit(0)
def handle_exit_gui(self):
self.cleanup()
self.root.destroy()
sys.exit(0)
def run_cmd(self, cmd, silent=False):
try:
if silent:
subprocess.run(cmd, shell=True, stdout=subprocess.DEVNULL, stderr=subprocess.DEVNULL, check=False)
return ""
else:
result = subprocess.run(cmd, shell=True, capture_output=True, text=True, check=False)
return result.stdout
except Exception as e:
print(f"Error running command {cmd}: {e}")
return ""
def get_running_vms(self):
try:
qapp = qubesadmin.Qubes()
filtered = []
for vm in qapp.domains:
if (vm.is_running() and
vm.klass not in ['TemplateVM', 'AdminVM'] and
not vm.name.startswith("sys-") and
vm.name not in EXCLUDED_VMS):
filtered.append(vm.name)
return filtered
print(f"Error accessing qubesadmin: {e}")
return []
def get_listening_ports(self, vm):
# Removed the grep so we get all listening TCP ports
cmd = f'qvm-run -q --pass-io --no-gui --no-autostart {vm} "ss -ltn"'
output = self.run_cmd(cmd)
ports = []
for line in output.splitlines():
# Only process lines representing actively listening sockets
if not line.startswith("LISTEN"):
continue
parts = line.split()
# ss -ltn columns: State, Recv-Q, Send-Q, Local Address:Port, Peer Address:Port
if len(parts) >= 4:
addr_port = parts[3]
if ":" in addr_port:
# rsplit(":", 1) splits by the LAST colon to safely handle IPv6 addresses
addr, port = addr_port.rsplit(":", 1)
# Strip brackets from IPv6 formats (e.g., [::])
addr = addr.strip("[]")
# Include it if it listens on all interfaces (*, 0.0.0.0, ::)
# or explicitly on localhost (127.x.x.x, ::1)
if addr in ["*", "0.0.0.0", "::"] or addr.startswith("127.") or addr == "::1":
if port.isdigit():
ports.append(port)
return list(set(ports))
def refresh_vms(self):
vm_names = self.get_running_vms()
new_vms = {}
for name in vm_names:
new_vms[name] = VM(name, 0, 0)
self.vms = new_vms
# Keep valid connections, cleanup orphaned ones
active_connections = []
for conn in self.connections:
# If either the client or server VM was shut down, kill the pipe
if conn.client_name in self.vms and conn.server_name in self.vms:
active_connections.append(conn)
else:
self.kill_connection(conn)
self.connections = active_connections
self.render_vms()
threading.Thread(target=self.discover_ports_worker, daemon=True).start()
def kill_connection(self, conn):
if conn.process:
conn.process.terminate()
try:
conn.process.wait(timeout=1)
except subprocess.TimeoutExpired:
conn.process.kill()
kill_cmd = f'qvm-run -q --no-gui --no-autostart {conn.client_name} "pkill -f \'socat TCP-LISTEN:{conn.local_port}\'"'
subprocess.Popen(kill_cmd, shell=True, stdout=subprocess.DEVNULL, stderr=subprocess.DEVNULL)
def on_resize(self, event):
if abs(event.width - self.last_width) > 20:
self.last_width = event.width
self.render_vms(event.width)
def render_vms(self, width=None):
self.canvas.delete("vm_element")
if not width:
width = self.canvas.winfo_width()
if width < 10:
width = 1200
# Adjusted columns to account for wider screen space
cols = max(1, width // 280)
for i, (name, vm) in enumerate(self.vms.items()):
row = i // cols
col = i % cols
# Calculate center point for the VM box
vm.x = 140 + col * 280
vm.y = 80 + row * 160
self.draw_vm_box(vm)
if vm.ports:
self.update_vm_ports_ui(name, vm.ports)
self.redraw_connections()
self.draw_connection_line(conn)
def draw_vm_box(self, vm):
# Increased padding slightly for a "card" look
padding_x = 55
padding_y = 45
x1, y1 = vm.x - padding_x, vm.y - padding_y
x2, y2 = vm.x + padding_x, vm.y + padding_y
# Draw the main card body
vm.canvas_id = self.canvas.create_rectangle(
x1, y1, x2, y2,
fill=THEME["vm_bg"], outline=THEME["vm_border"], width=2,
tags=("vm_element", "vm_box", vm.name)
# Draw the VM Name text
self.canvas.create_text(
vm.x, vm.y,
text=vm.name, font=FONT_BOLD, fill=THEME["text_main"],
def discover_ports_worker(self):
for name, vm in self.vms.items():
ports = self.get_listening_ports(name)
self.root.after(0, self.update_vm_ports_ui, name, ports)
def handle_source_vm_click(self, vm):
if self.selected_source_vm == vm:
self.canvas.itemconfig(vm.canvas_id, fill=THEME["vm_bg"], outline=THEME["vm_border"])
return
if self.selected_source_vm:
self.canvas.itemconfig(self.selected_source_vm.canvas_id, fill=THEME["vm_bg"], outline=THEME["vm_border"])
self.selected_source_vm = vm
self.canvas.itemconfig(vm.canvas_id, fill=THEME["vm_sel_bg"], outline=THEME["vm_sel_border"])
def update_vm_ports_ui(self, name, ports):
vm = self.vms[name]
vm.update_ports(ports)
padding_x = 55
padding_y = 45
x2 = vm.x + padding_x
y1 = vm.y - padding_y
y2 = vm.y + padding_y
for i, port in enumerate(ports):
py = y1 + (i + 1) * (y2 - y1) / (len(ports) + 1)
# Draw port circle
port_id = self.canvas.create_oval(
x2-6, py-6, x2+6, py+6,
fill=THEME["port_fill"], outline=THEME["port_border"], width=1,
tags=("vm_element", "port")
# Draw port text
x2+24, py,
text=port, font=FONT_MAIN, fill=THEME["text_main"],
tags=("vm_element", "port_text")
vm.port_ids[port] = port_id
# Redraw connections now that new port coordinates are known
def on_click(self, event):
item = self.canvas.find_closest(event.x, event.y)
if not item:
return
item_id = item[0]
tags = self.canvas.gettags(item_id)
if "port" in tags or "port_text" in tags:
# User clicked near/on a destination port
for vm in self.vms.values():
for port, pid in vm.port_ids.items():
# Check distance manually to be generous with clicks if they hit the text
coords = self.canvas.coords(pid)
if coords:
cx = (coords[0] + coords[2]) / 2
cy = (coords[1] + coords[3]) / 2
if abs(event.x - cx) < 40 and abs(event.y - cy) < 15:
self.handle_target_port_click(vm, port)
return
elif "vm_box" in tags:
vm_name = tags[2]
self.handle_source_vm_click(self.vms[vm_name])
def handle_target_port_click(self, target_vm, remote_port):
if not self.selected_source_vm:
messagebox.showinfo("Select Client", "Please click a VM box first to select the source Client.")
return
client_vm = self.selected_source_vm
if client_vm.name == target_vm.name:
messagebox.showwarning("Warning", "Cannot connect a VM to itself.")
self.canvas.itemconfig(client_vm.canvas_id, fill=THEME["vm_bg"], outline=THEME["vm_border"])
return
local_port = remote_port
self.create_connection(client_vm.name, local_port, target_vm.name, remote_port)
# Reset visual selection
def create_connection(self, client_name, local_port, server_name, remote_port):
rule = f"qubes.ConnectTCP +{remote_port} {client_name} {server_name} allow\n"
try:
with open(POLICY_FILE, "a") as f:
f.write(rule)
messagebox.showerror("Error", f"Failed to write policy: {e}")
return
time.sleep(0.5)
cmd = f'qvm-run --pass-io --no-gui --no-autostart {client_name} "qvm-connect-tcp {local_port}:{server_name}:{remote_port}"'
process = subprocess.Popen(cmd, shell=True, stdout=subprocess.DEVNULL, stderr=subprocess.DEVNULL)
conn = Connection(client_name, local_port, server_name, remote_port)
conn.process = process
self.connections.append(conn)
def on_right_click(self, event):
if not item:
return
tags = self.canvas.gettags(item[0])
if "connection" not in tags:
return
# Find the unique connection tag we assigned
conn_tag = next((t for t in tags if t.startswith("conn_")), None)
if not conn_tag:
return
# Match the tag to the connection object
target_conn = next((c for c in self.connections if f"conn_{id(c)}" == conn_tag), None)
if not target_conn:
return
if messagebox.askyesno(
"Delete Connection",
f"Sever connection from {target_conn.client_name} to {target_conn.server_name}:{target_conn.remote_port}?"
self.delete_connection(target_conn)
def delete_connection(self, conn):
# 1. Kill the socat process
# 2. Remove from active connections list
if conn in self.connections:
self.connections.remove(conn)
# 3. Remove rule from policy file
self.remove_policy_rule(conn)
# 4. Refresh UI
def remove_policy_rule(self, conn):
rule_to_remove = f"qubes.ConnectTCP +{conn.remote_port} {conn.client_name} {conn.server_name} allow\n"
if not os.path.exists(POLICY_FILE):
return
try:
# Read all lines, keep everything except the one we want to delete
with open(POLICY_FILE, "r") as f:
lines = f.readlines()
with open(POLICY_FILE, "w") as f:
for line in lines:
if line != rule_to_remove:
f.write(line)
messagebox.showerror("Error", f"Failed to update policy file: {e}")
def draw_connection_line(self, conn):
client_vm = self.vms.get(conn.client_name)
server_vm = self.vms.get(conn.server_name)
if not client_vm or not server_vm or conn.remote_port not in server_vm.port_ids:
return
src_x, src_y = client_vm.x, client_vm.y
dst_coords = self.canvas.coords(server_vm.port_ids[conn.remote_port])
# BUG FIX: Prevent crash if the port hasn't been rendered yet
if not dst_coords:
return
dst_x = (dst_coords[0] + dst_coords[2]) / 2
dst_y = (dst_coords[1] + dst_coords[3]) / 2
# Create a unique tag for this specific connection
conn_tag = f"conn_{id(conn)}"
conn.line_id = self.canvas.create_line(
src_x, src_y, dst_x, dst_y,
fill=THEME["line"], width=2.5, arrow=tk.LAST,
tags=("vm_element", "connection", conn_tag)
text_x, text_y = src_x + (dst_x - src_x) * 0.25, src_y + (dst_y - src_y) * 0.25
text_id = self.canvas.create_text(
text_x, text_y,
text=f" L:{conn.local_port} ", font=FONT_BOLD, fill=THEME["line"],
bbox = self.canvas.bbox(text_id)
if bbox:
bg_rect = self.canvas.create_rectangle(
bbox[0]-2, bbox[1]-2, bbox[2]+2, bbox[3]+2,
fill=THEME["bg"], outline=THEME["line"], width=1,
self.canvas.tag_lower(bg_rect, text_id)
self.canvas.tag_lower(conn.line_id, bg_rect)
def redraw_connections(self):
self.canvas.delete("connection")
def cleanup(self):
print("Cleaning up temporary pipes...")
if os.path.exists(POLICY_FILE):
try:
os.remove(POLICY_FILE)
except Exception:
pass
if __name__ == "__main__":
root = tk.Tk()
# Set a minimum window size so the UI doesn't crush
root.minsize(800, 600)
app = QubePipesApp(root)
root.mainloop()
E: couple of bug fixes
E2: added ability to right click delete connections
