This might be an easy issue… But i get this error, and i think it’s because i tried to install librewolf but had some error… not sure. i did also clone a qube but that might not be it. How do i fix this?
$ sudo apt-get update
Err:1 https://deb.debian.org/debian bullseye InRelease
Temporary failure resolving 'deb.debian.org'
Err:2 https://deb.debian.org/debian-security bullseye-security InRelease
Err:3 https://deb.qubes-os.org/r4.1/vm bullseye InRelease
Temporary failure resolving 'deb.qubes-os.org'
Reading package lists... Done
E: Failed to fetch https://deb.debian.org/debian/dists/bullseye/InRelease Temporary failure resolving 'deb.debian.org'
E: Failed to fetch https://deb.debian.org/debian-security/dists/bullseye-security/InRelease Temporary failure resolving 'deb.debian.org'
E: Failed to fetch https://deb.qubes-os.org/r4.1/vm/dists/bullseye/InRelease Temporary failure resolving 'deb.qubes-os.org'
E: Some index files failed to download. They have been ignored, or old ones used instead.
You haven’t said, and no one has asked you.
Do you only get this error in the template where you installed
librewolf. Are your other templates updating fine?
That fragment of code you quote couldn’t affect the standard repository
definitions.
Hello. Thanks, but no it’sonly that cube… I do get this in fedora which is wierd, but that seems to be something i dont understand in fedora:
sudo dnf update && sudo dnf upgrade -y
Last metadata expiration check:
Dependencies resolved.
Package Arch Version Repository Size
Upgrading:
gstreamer1-plugin-openh264 x86_64 1.20.3-1.fc36 fedora-cisco-openh264 25 k
mozilla-openh264 x86_64 2.3.0-1.fc36 fedora-cisco-openh264 428 k
openh264 x86_64 2.3.0-1.fc36 fedora-cisco-openh264 423 k
Transaction Summary
Upgrade 3 Packages
Total download size: 876 k
Is this ok [y/N]: y
Downloading Packages:
(1/3): gstreamer1-plugin-openh264-1.20.3-1.fc36 5.6 kB/s | 25 kB 00:04
(2/3): openh264-2.3.0-1.fc36.x86_64.rpm 71 kB/s | 423 kB 00:05
(3/3): mozilla-openh264-2.3.0-1.fc36.x86_64.rpm 68 kB/s | 428 kB 00:06
Total 104 kB/s | 876 kB 00:08
Package gstreamer1-plugin-openh264-1.20.3-1.fc36.x86_64.rpm is not signed
Package mozilla-openh264-2.3.0-1.fc36.x86_64.rpm is not signed
Package openh264-2.3.0-1.fc36.x86_64.rpm is not signed
The downloaded packages were saved in cache until the next successful transaction.
You can remove cached packages by executing 'dnf clean packages'.
Error: GPG check FAILED
[user@fedora-36 ~]$ ^C
[user@fedora-36 ~]$
I just need to clean something i added that’s all. Can someone answer to why there are no signatures in fedora? Debian seems better… Maybe someone forgot to sign and uploaded?
The Fedora error is because you have gpgcheck enabled in the Fedora repo
definition, but fedora packages are not signed. Those are all from the
same repository, which makes me wonder if the gpgcheck is not
appropriate there. (I don’t know, but I wonder.)
With the Debian issue, its strange. If your other updates are working
properly then obviously the connection at the proxy is fine, and it
doesn’t look as if there’s anything wrong with the definition - https://deb.debian.org/ is standard stuff.
Can you confirm that the only change you made was that librewolf repo?
For the past month or so I’ve seen a similar error involving the failure to update the InRelease file when I update any of my Debian templates, on multiple machines. Since I update via sys-whonix (using the .onion repos), I’m accustomed to update failures like this from time to time and a second, or third, attempt is usually sufficient to successfully complete the update. The difference is that the errors now seem to be happening more consistently and always involving the InRelease file. However, most packages update fine on the first attempt despite the error.
For example:
Updating whonix-ws-16
Error on updating whonix-ws-16: Command '['sudo', 'qubesctl', '--skip-dom0', '--targets=whonix-ws-16', '--show-output', 'state.sls', 'update.qubes-vm']' returned non-zero exit status 20
whonix-ws-16:
Function: pkg.uptodate
Result: False
Comment: E: Release file for tor+https://fasttrack.debian.net/debian/dists/bullseye-fasttrack/InRelease is not valid yet (invalid for another 48s). Updates for this repository will not be applied.
