Dracut-initqueue Timeout Issues
Bu şekilde hata veriypr yardımıcı olnuz lütfen
Translation (Turkish to English using Google Translate engine)
Please help me if I get an error like this
[1] On what exact hardware did you try?
[2] Did you read the documentation?
[3] Please study the instructions carefully and ensure that you have met all the prerequisites (IOMMU virtualisation settings, secure boot, etc.).
I did it on a casper laptop I registered on base via the rüfus and after completing everything, I encounter such a bug during the installation phase
I deleted the USB again several times and wrote it again. But I couldn’t get to the installation stage. I made the bios settings one by one intel vmx virtualization technology and intel vd-d I also opened them. secruboot I closed this too. but the problem still persists
I followed the setup, but after the bayost during the installation phase, the USB memory is called the name that should work. I followed the installation, but during the installation phase, the USB memory should work after the bayost is called the In this step, when we select the option as test or inslate, it does not take any action when we select it as installation. After the system control, the installer does not come to the momentary stage
I don’t know that brand. Would you mind linking some page with the model’s details?
My friend already has a low sixteen GB ram and an SSD in the computer, so I don’t think he does it in terms of a computer, he needs to get another error, but I can’t find it. So now, for example, it just started to give very ridiculous errors while researching, the USB driver changed its memory. I increased it from four to two without gene
CPU model / chipset?
İntel
Which one?
https://www.akakce.com/laptop-notebook/en-ucuz-casper-nirvana-s500-1021-8c50f-g-f-i5-10210u-8-gb-120-gb-ssd-mx230-15-6-full-hd-notebook-fiyati,692532200.html Sorry PC this rm 16 gb 250sdd upgrade
