Dom0 Update Issue
When I try to update my dom0, I get this. (version 4.2.1)
Detailed information will be displayed after update.
dom0 does not support in-progress update information.
Error on updating dom0: Command '['sudo', 'qubesctl', '--dom0-only', '--no-color', 'pkg.upgrade', 'refresh=True']' returned non-zero exit status 1.
[ERROR   ] Command 'systemd-run' failed with return code: 1
[ERROR   ] stdout: e[0;31m0 files removed
e[0m
[ERROR   ] stderr: Running scope as unit: run-r77c08fdb6b8d421d9c49b17070c12e11.scope
Using sys-firewall as UpdateVM to download updates for Dom0; this may take some time...
'/usr/lib/qubes/qrexec-client-vm dom0 qubes.ReceiveUpdates /usr/lib/qubes/qfile-agent /var/lib/qubes/dom0-updates/packages/*.rpm' failed with exit code 1!
[ERROR   ] retcode: 1
Error running 'pkg.upgrade': Problem encountered upgrading packages. Additional info follows:
changes:
result:
    pid:
        15839
    retcode:
        1
    stderr:
    stdout:
        0 files removed
I know that there have been many other posts of people with this issue, however I can’t find any answer that contains some information on what I can actually do to solve this.
Try to run sudo qubes-dom0-update in dom0 terminal, maybe there will be more log messages.
It seems that after waiting a while the issue fixed itself. Had something to do with key signing and it seems like this was a issue in 4.0.x but got resolved now.
