I did something stupid and now my dom0 won 't boot due to missing files. I have a backup I can restore from but it is like 2 months old.
I was wondering if there was a way to just reinstall dom0 or “do a factory reset on just dom0”.
I don’t see any reason why I can’t use the same vm block devices, at the very least for my standalone vms. I have access to dom0 root and all the file systems so I could even get the config files for all the qubes etc.
Is there any way to do this? If not, I should at least be able to boot my standalone vms with a normal xen installation on normal linux? Does anyone know how to do that? I used kpartx to mount the root of my standalone and all the partitions are there including the EFI partition so I don’t see why I couldn’t at least keep the standalones.
If dom0 reset isn’t apart of the installer, maybe it is a feature worth consideration?
