Does dom0 kernel contain BPF? Are there any LSMs available to harden the dom0
kernel?
kernel?
Check:
root@dom0:~ # journalctl -b -o short-monotonic | grep -i bpf
also
root@dom0:~ # zgrep -i bpf /proc/config.gz
dom0 audit: BPF prog-id=7 op=LOAD
dom0 audit: BPF prog-id=7 op=UNLOAD
there are about 40 entries of program IDs (prog-id) but I don’t know which programs
they are.
CONFIG_BPF=y
CONFIG_HAVE_EBPF_JIT=y
CONFIG_BPF_SYSCALL=y
there are a bunch of remaining globals with values of “y” or “m” but I don’t know what
they all mean.
/proc/config.gz contains the configuration of the currently running kernel.
‘m’ means module.
‘y’ means statically built.
