Dom0 4.3.2 upgrade issue
Get this when trying to update from 4.3.1 to 4.3.2
Checking for available updates for dom0...
Using sys-whonix as UpdateVM for Dom0
Checking for dom0 updates...
Available updates:
Fedora 41 - x86_64                              2.7 kB/s | 4.6 kB     00:01
Fedora 41 - x86_64 - Updates                    2.8 kB/s | 4.5 kB     00:01
Qubes Host Repository (updates)                 1.9 kB/s | 3.2 kB     00:01
qubes-release.noarch                   4.3-6.fc41             qubes-dom0-current
qubes-release-notes.noarch             4.3-6.fc41             qubes-dom0-current
There are dom0 updates available
Downloading updates. This may take a while...
Failed to connect to system scope bus via local transport: Operation not permitted (consider using --machine=@.host --user to connect to bus of other user)
Any suggestions?
Get in line, specifically here lol: Unable to update: "Failed to connect to system scope bus via local transport" - #11 by rustybird
Yes: restart sys-whonix, make sure the Tor connection is up, or even better wait for the sdwdate widget (padlock) to be complete/locked. Then try the update again.
I updated earlier without problems.
I’m doing a backup because it’s been awhile will try again when it’s done and report back here
Thanks for trying to help us, but I tried everything you wrote here and it does not change anything unfortunately. Still got the same error and can’t update dom0 (over sys-whonix).
Also please let us keep it in the thread I linked in my first reply here, so we don’t have multiple threads talking about the same problem.
Yeah, probably a Qubes repo problem? see my post here.
