Does Qubes run on Xeon v3 cpus
Dear All I intend to purchase a board for 2 xenon v3 cpus. Will i ba=e able to install qubes 4.0.4?
Many thanks.
Hi @drjam. Hardware compatibility of Qubes is hard to anticipate. What you can do is make sure it has the hardware requirements
And then check on the hardware compatibility list (HCL) if a device with similar hardware has successfully run Qubes:
(adjusted the title for clarity)
I intend to purchase a board for 2 xenon v3 CPUs. Will I be able to
There is much more that goes into answering that question: what chipset,
what network controller(s) etc. What I can offer you is a simple query
over the existing HCL reports:
These Xeon chips are mentioned in positive HCL reports for R4.0:
[1] E3-1535M v6 @ 3.10GHz
[2] L5638 @ 2.00GHz
[3] W-2155 @ 3.30GHz
[4] Silver 4114 @ 2.20GHz
[5] E5-2680 0 @ 2.70GHz
[6] E5-2690 0 @ 2.90GHz
[7] E-2176M @ 2.70GHz
[8] W-2123 @ 3.60GHz
… and for R4.1:
[9] E3-1505M v6 @ 3.00GHz
Here the links into the HCL:
[1]
[2]
[3]
[4]
[5]
[6]
[7]
[8]
[9]
Note: I fixed the title mistake : Xenon → Xeon
Thanks so much everyone. oops sorry the typing error xeon and not xenon.
