Say you have 3 vm all going through same whonix gateway. I know each vm will have different tor ip but will all 3 share the same guard node? If that’s the case would it be easy to link all 3 vm as the same person?
I personally use 5 or more Tor contraptions. There is no easy way to tell you which is better for your threat model. Is is anon-surf, tor-client, tor-server, multiple-whonix etc? I do recommend multiple whonix in cases you run i2pd nodes or other encrypted networks. The simplistic way/approach of Whonix forum is just a very particular case. I personally consider them untrusted/hostile until proven. So is Qubes…
