Following up a question a user had about installing Qubes from a USB stick, I noticed something was missing from the installation instructions :
Given this changes wildly from computer to computer, I wanted to ask for feedback on my specific proposal, in case you can spare the time. I specifically would like to know if my changes would work in situations you’ve come across:
QubesOS:master ← deeplow:patch-23
opened 06:41PM - 05 Jul 21 UTC
Fixes QubesOS/qubes-issues/issues/6758
if you want to give general feedback about how to document this, then please do so in the associated issue:
opened 11:10AM - 03 Jul 21 UTC
closed 07:50PM - 10 Jul 21 UTC
T: enhancement
C: doc
P: default
### Checklist
- [x] I have [searched both open and closed issues](https://www.q… ubes-os.org/doc/issue-tracking/#search-tips) for duplicates.
- [x] This issue follows the [Issue Tracking Guidelines](https://www.qubes-os.org/doc/issue-tracking/#guidelines).
### The problem you're addressing (if any)
The current description of how to boot from a USB stick is highly non-trivial for anyone who has never installed an operating system (most Windows and Mac users). It currently [only states](https://www.qubes-os.org/doc/installation-guide/#getting-to-the-boot-screen):
> ### Getting to the boot screen
> Just after you power on your machine, make the Qubes OS medium available to the
computer by inserting your DVD or USB drive. This step is a little tricky
> Shortly after the Power-on self-test (POST) is completed, you should be greeted with the Qubes OS boot
screen.
### Describe the solution you'd like
A description on how to get into a boot menu on most computers.
### Where is the value to a user, and who might that user be?
Non-tecnical users who have never installed any OS and never even heard the word BIOS or how it looks like.
### Describe any alternative solutions you've considered
Leaving users stranded in the step.
### Additional context
- inspired by this thread: [Installing Qubes From USB Drive](https://forum.qubes-os.org/t/installing-qubes-from-usb-drive/4866)
### Relevant [documentation](https://www.qubes-os.org/doc/) you've consulted
<!--(Provide a list of any relevant documentation you've consulted. We do not
know what you've already read unless you tell us. If you do not list anything,
we will assume that you haven't read any relevant documentation. If you're not
aware of any relevant documentation, write "None" (or "N/A" if not
applicable).)-->
- https://www.qubes-os.org/doc/installation-guide/#getting-to-the-boot-screen
### Related, [non-duplicate](https://www.qubes-os.org/doc/issue-tracking/#new-issues-should-not-be-duplicates-of-existing-issues) issues
<!--(Provide a list of any related issues of which you're aware. Do not
describe any other unreported bugs, features, or tasks here. We do not know
which issues you've already seen unless you tell us. If there is another issue
that seems like a duplicate, and you did not mention it here, we will assume
that you were not aware of it. If you didn't find any related issues, write
"None found.")-->
- https://github.com/QubesOS/qubes-issues/issues/5634
