Took these notes about little typos and things while reading the docs. I had to drop my patch effort but figured the community might as well have it. They could be something easy for someone to run through as a first contribution.
There’s a few examples of how I did the PRs.
- Issue tracking: Fix unclosed link
- Issue tracking: Fix all bugs link
- Support: Add missing word
- Support: Remove duplicate word
Choosing your hardware
Certified hardware
- Requirements, “must be be available”
Downloading, installing, and upgrading Qubes
Installation guide
Copying the ISO onto the installation medium:
- “We strongly recommended making …” → recommend
Getting to the boot screen:
- “is may be called”
- “To give you and idea of”
Localization:
- “You can have as many keyboard layout and …”
Installation destination:
Initial Setup:
- “Enabling system and template updates …” → Enable, for consistency
Get Started:
- “Find out Getting Started …” → how to get started
Getting help:
- “… accurate, comprehensive useful and …” → comprehensive, useful and
Supported releases
Qubes OS:
- Release 4.3, remove milestone link, obsolete.
Testing new releases and updates
Updates:
- “that is up the …” → up to the
Templates
Templates
Note on treating app qubes’ root filesystem non-persistence …:
- “and surely many others places” → other
- “might got maliciously modified” → might be, might have gotten
Project security
Verifying signatures
Qubes Master Signing Key:
- “many Qubes team member keys” → any?
cryptographic hash values:
- “which can find” → which you can find
- “and you can always” → you can always
I have another problem that isn’t mentioned here:
- “Still have question?” → Still have a question?
Releases
Version scheme
Lead:
- “and major release are” → releases
Release schedule:
- “and tested by wider user base.” → a wider
Bug priorities:
- “only last resort option” → a last resort
- “existence of such bugs do not” → does not, 2x
- “be considered final” → from being considered, 2x
- “All above is about” → All of the above
- “after first” → after the first
Git tags and branches:
- “by tag containing” → by a tag containing
- “by R tag.” → by an R tag
- “in master branch.” → in the master branch
- “depending on maintainer of repository.” → on the maintainer
Check installed version:
- “in the Qubes Manager” → Qube Manager
Releases
Release checklist
On final release:
- “update installationinstructions” → installation instructions
Developer documentation
General
How to edit the documentation
Security:
- “prior to be merged” → being merged
General
Documentation style guide
Headings:
- “##h2” → ## h2 [confirm not intentional]
English language conventions:
- “for the sake consistency” → for the sake of
Do not duplicate documentation:
- “as some point” → at some point
Code
Source code
- “GUI virtualization, Dom0 side” → GUI qube side
Code
Coding style
Rationale:
- “back fired” → backfired
- “sometime months” → sometimes months
- “sometime years” → sometimes years
- “lead to a real” → led to a real
General typographical conventions:
- “for argument and variables” → arguments
- “CRLF line endings (-).” → remove (-), or replace with (‘\r\n’)
File naming conventions:
- “/etc/qubes-rpc/policy/” → /etc/qubes/policy.d/
- “the current state of system” → of the system
- “All base qubes-related file” → Qubes-related
- “But generally, there is little excuse” → conformant alert
Source Code management (Git) guidelines:
- “for Qubes project.” → the Qubes project
Security coding guidelines:
- “Any input that comes from … entity” → an … entity
- “read from untrusted party” → an untrusted party
- “Use others variables” → other
Python-specific guidelines:
- “unless they were” → unless they are
C and C++ specific guidelines:
- “Think about classes hierarchy” → the class hierarchy
Bash-specific guidelines:
- “in Windows admin domain” → a Windows admin domain
- “Windows gui domain” → GUI
Code
Code signing
Generating a Key:
- Heading to sentence case.
Upload the Key:
- “last 8 hex digits” → last 16, or last 8 bytes in hexadecimal
- Remove duplicate example.
Using PGP with Git:
- “which you like to” → would like to
GitHub Signature Verification (optional):
- Confirm links, SSH mention probably wrong.
Code Signature Checks:
- “using the any key” → using any key
Using PGP with Email:
System
GUI virtualization
Window content updates implementation:
- “to the GUI daemon using using the” → deduplicate using
- “mnfs” → mfns
- “specified by qubes-guid” →
qubes-guid, for consistency
Security markers on dom0 windows:
- “to belong to other AppVM” → another AppVM
AppVM → GuiVM messages:
- Stray tag
Templates
Minimal templates
Passwordless root:
- “from which you can use execute root commands” → remove use
CentOS:
- “to a standard Debian template” → remove paragraph, align with Fedora
Templates
Xfce templates
Installation:
- “The Fedora Xfce templates can be installed …” → remove Fedora, general
Advanced topics
Volume backup and revert
- “it’s volumes are stored” → its
- “from the the above list” → deduplicate
Advanced topics
How to mount a Qubes partition from another OS
Accessing LVM Logical Volumes:
- “for it’s LVM VG.” → its
Introduction
Code of Conduct
- “the Marek” → remove article
