Hi everyone, I am new to Qubes, and recently fresh install R4.1 on my machine(Debian 11 & Whonix 16 template) . I’m experiecing to replaced the sys template with Kicksecure 16 but now facing an issue.
I’ve installed a debian-11-minimal template, and morphing to Kicksecure 16 by following this guide , also followed this guide to install these packages:
qubes-core-agent-networking
qubes-core-agent-network-manager
qubes-core-agent-dom0-updates
qubes-usb-proxy
qubes-input-proxy-sender
pciutils
Also followed the guide on the Qubes’github to anonymizing mac address, hostname anonymize was not done yet.
However, everything seems works fine but the sys-net, before changing the template (which is Debian 11), it works great without any issue, but after my little(?) configuration mentioned above, it cannot work to connect Wi-Fi. When I open the Network Manager Applet from the panel, it showsNo network device available. (But it can be connected to the internet with usb-ethernet adapter)
What I’ve do:
1. Go to Qubes Manager -> Settings: sys-net
-> Device Tab -> check is the NIC selected
Result: Selected device: Intel AX201 (which is the only NIC on my machine)
2. run command: sudo dmsg | grep iwlwifi
Result:
[ 2.632527] iwlwifi 0000:00:06.0: Direct firmware load for ielwifi-QuZ-a0-hr-b0-59.ucode failed with error -2
[ 2.63542] (other version of iwlwifi.ucode failed with error -2)
[ 2.632527] iwlwifi 0000:00:06.0: minimum version supported: iwlwifi-QuZ-a0-hr-b0-39
[ 2.632527] iwlwifi 0000:00:06.0: maximum version supported: iwlwifi-QuZ-a0-hr-b0-59
3. lspci
Result:
00:06.0 Network controller: Intel Corporation Wi-Fi 6 AX201 (rev 20) exist
I know it might just be a stupid issue, but now I need some help and advice to make the wireless work in my machine, Thanks a lot. (Sorry for my grammar as English is not my first language)
