Disposable /rw/config/ not saved on reboot - SELinux restorecon Solution
THANKS FOR QUBES !!
but, i came across this situation while installing QuBes with a disposable sys-net
i edited the config files using NetworkManager on ‘sys-net’ (removed the hardware details) and copied those files to the Disposable template (dvm-sys-net)
As described in the first portion of this forum posting:
the issue
while i am able to copy the config files to dvm-sys-net
connect to dvm-sys-net from dom0 with:
qvm-run -a dvm-sys-net xterm
and, create the folders required with:
[user@dvm-sys-net: ~] sudo mkdir -p /rw/config/NM-system-connections/
copy the config files in there, and shutdown using the Qubes Manager
and restart sys-net
Unfortunately, the WIFI is not connecting automatically as expected.
it would be really great if somebody could point out the error of my ways, and explain the manner to resolve these issues.
Thanks in advance,
When you start the qube based on this dvm-sys-net disposable template, check the logs and see what’s wrong:
journalctl -b -u NetworkManager
Also check in /rw/config/NM-system-connections if your files are there.
Thanks for your suggestions @DVM
in sys-net
Dec 29 07:27:02 sys-net NetworkManager[621]: <info>  [1735475222.9811] settings: Loaded settings plugin: keyfile (internal)
Dec 29 07:27:02 sys-net NetworkManager[621]: <warn>  [1735475222.9827] keyfile: load: "/etc/NetworkManager/system-connections/wifi-New.nmconnection": failed to load connection: cannot access file: Permission denied
Dec 29 07:27:02 sys-net NetworkManager[621]: <warn>  [1735475222.9828] keyfile: load: "/etc/NetworkManager/system-connections/wifi-Old.nmconnection": failed to load connection: cannot access file: Permission denied
Dec 29 07:27:02 sys-net NetworkManager[621]: <info>  [1735475222.9877] dhcp: init: Using DHCP client 'internal'
[user@sys-net ~]$ ls -la /etc/NetworkManager/system-connections/
total 16
drwxr-xr-x. 2 root root 4096 Dec 28 13:38 .
drwxr-xr-x. 3 root root 4096 Sep  3 14:27 ..
-rw-------. 1 root root  309 Nov 25 07:12 wifi-New.nmconnection
-rw-------. 1 root root  351 Sep 30 12:45 wifi-Old.nmconnection
And, for some reason, the /run/config in dvm-sys-dev seems to have resolved itself;
Truth be told, there were changes to the permissions and ownership of the files as [ root:root , 0600 ]
thus, in dvm-sys-net :
[user@dvm-sys-net ~]$ sudo ls -lah /etc/NetworkManager/
total 32K
drwxr-xr-x.   7 root root 4.0K Dec 23 09:25 .
drwxr-xr-x. 119 root root 4.0K Dec 29 10:20 ..
-rw-r--r--.   1 root root 2.3K Dec 23 09:25 NetworkManager.conf
drwxr-xr-x.   2 root root 4.0K Jun 23  2024 conf.d
drwxr-xr-x.   5 root root 4.0K Dec 23 09:25 dispatcher.d
drwxr-xr-x.   2 root root 4.0K Jun 23  2024 dnsmasq-shared.d
drwxr-xr-x.   2 root root 4.0K Jun 23  2024 dnsmasq.d
drwxr-xr-x.   2 root root 4.0K Jun 23  2024 system-connections
[user@dvm-sys-net ~]$ sudo ls -lah /rw/config/NM-system-connections/
total 16K
drw-------. 2 root root 4.0K Dec 28 13:38 .
drwxr-xr-x. 3 root root 4.0K Sep  3 14:27 ..
-rw-------. 1 root root  289 Dec 29 09:26 wifi-New.nmconnection
-rw-------. 1 root root  289 Dec 29 09:26 wifi-Old.nmconnection
Thanks to your suggestions, dvm-sys-net appears to be solved after files & directories permissions were fixed as per warn found in journalctrl
outstanding issue
sys-net is not using the config ((*.nmconnection)) files due permissions ?
Thanks,
Could it be a SELinux issue?
Do you see any denied logs related to the NetworkManager connection?
journalctl -b | grep denied
yes, there are entries found …
[user@sys-net ~]$ sudo journalctl -b | grep -i denied
Dec 29 09:38:14 sys-net audit[622]: AVC avc:  denied  { getattr } for  pid=622 comm="NetworkManager" path="/rw/config/NM-system-connections/wifi-New.nmconnection" dev="xvdb" ino=115 scontext=system_u:system_r:NetworkManager_t:s0 tcontext=unconfined_u:object_r:qubes_unpacked_file_t:s0 tclass=file permissive=0
Dec 29 09:38:14 sys-net audit[622]: AVC avc:  denied  { getattr } for  pid=622 comm="NetworkManager" path="/rw/config/NM-system-connections/wifi-Old.nmconnection" dev="xvdb" ino=108 scontext=system_u:system_r:NetworkManager_t:s0 tcontext=unconfined_u:object_r:qubes_unpacked_file_t:s0 tclass=file permissive=0
Dec 29 09:38:14 sys-net NetworkManager[622]: <warn>  [1735483094.0054] keyfile: load: "/etc/NetworkManager/system-connections/wifi-New.nmconnection": failed to load connection: cannot access file: Permission denied
Dec 29 09:38:14 sys-net NetworkManager[622]: <warn>  [1735483094.0054] keyfile: load: "/etc/NetworkManager/system-connections/wifi-Old.nmconnection": failed to load connection: cannot access file: Permission denied
What happens if you run this on both files in the disposable template:
restorecon -v /rw/config/NM-system-connections/wifi-New.nmconnection
restorecon -v /rw/config/NM-system-connections/wifi-Old.nmconnection
below are the result of commands;
[user@dvm-sys-net ~]$ sudo restorecon -v /rw/config/NM-system-connections/wifi-New.nmconnection
Relabeled /rw/config/NM-system-connections/wifi-New.nmconnection from unconfined_u:object_r:qubes_unpacked_file_t:s0 to unconfined_u:object_r:NetworkManager_etc_rw_t:s0
[user@dvm-sys-net ~]$ sudo restorecon -v /rw/config/NM-system-connections/wifi-Old.nmconnection
Relabeled /rw/config/NM-system-connections/wifi-Old.nmconnection from unconfined_u:object_r:qubes_unpacked_file_t:s0 to unconfined_u:object_r:NetworkManager_etc_rw_t:s0
Thanks @DVM
I have restarted sys-net (a few times) and it is now connecting by itself - as expected !!
Would you mind giving some idea for this issue ?
Do you want me to explain what fixed the issue or something else?
I figure that there were SELinux interfering in the process.
However, it is not clear why QuBes /rw/config implementation would not have taken SELinux into consideration.
The sys-usb & sys-net are using Fedora templates - since Fedora appears to be better supported by QuBes.
So it is a curious thing to find this issue.
Is this a Bug that should be reported ?
Thanks for your assistance
You had this issue because you moved both files from another qube, which changed their labels to something else related to the qube’s unpacker binary used to exchange files between qubes.
Since SELinux is strict about what services can access what, NetworkManager couldn’t access the two configuration files because they weren’t labeled with its own labels. restorecon restored the labels to the correct NetworkManager_etc_rw_t label, which allowed NetworkManager to access them.
Thanks @DVM for parting this information!
It is super important - and helpful - for the newbies, such as myself, to understand these issues.
It is also super important to mark @DVM 's solution as “SOLUTION” so people find it quickly,
thanks @barto
flagged the solution - still getting used to the forum’s web-app
