This issue started with when i got this error message “usb is not restricted in dom0” after reading few same posts in forum tried creating the sys-usb myself.
created a simple qube with hvm as the mode(not sure what that does) and assigned usb ports to it.
now read a post here which created sys usb through the sudo qubesctl state.sls qvm.sys-usb command in the terminal. exeut4ed that command some text showed up then nothing. checked qubes manager, only the sys-usb i created was there. so decided to delete it. and then restarted the system.
Now when i boot the system there is not text box to enter the disk password
checked the log… it gives
[ok] Reached target paths.
[ok[ Started Show Plymouth boot screen.
[ok] Forward Password R…s to Plymouth Directory watch
This repeats several times
then
warning: somepath/qubes_dom0-root doesnot exist
warning: root does not exist
warning: swap does not exist
warning: luks uuid not found
Entering emergency mode
press enter for manitenenca
Warning: not all diskss have been found
warning: you might want to regenerate your initramfs.
I have no clue how to fix this never used linix or any text based OS, not at all familiar with this system.
